Question about Jensen JR500 Remote Control
Cannot find which is the SET button on my URC22B
There is no button marked SET on the URC22B. Could it be the centre button on the Forward / Rewind cluster of 5 buttons? The instructions do not have an illustrated diagram of the positions of the buttons and their actions. Shall be grateful for any help.
Ivan, London. 10 Jan 2009
The set button is underneath the power button
Posted on Feb 08, 2009
Magnavox tv lost pause, rewind buttonstv problems
This simply sounds like a "remote address" problem, in other words--the remote is not assigned to the set. If this is for a DVD or VCR, you might have to assign that function before they work--by pressing the "dvd" or "vcr" button before they work.
Oct 02, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a eur7711150 remote for a panasonic radio that was my dads.. i cant figure out how to change channels on the radio.. hate to sound so stupid but there doesnt seem to be a tuner or a seek button
The EUR7711150 remote works for several different Panasonic CD stereo systems. To switch between AM and FM, press the Tuner/Band button. (If you were in another mode, you'll need to press the Tuner/Band button once to get to the Tuner mode and then toggle if needed.) Then if you press Play Mode (above Repeat to the left of the number keys), you can toggle between Preset and Manual. In Preset, the rewind and fast forward buttons select between your preset stations. Alternatively, you can set the presets to numerical values and touch the appropriate number button. (Touch the >=10 button first to access Memories 10-15.) If you are on Manual, the rewind and fast forward buttons will let you move up and down between the frequencies. Pressing and holding Rewind or Fast Forward for a moment will let the radio scan to the next frequency in that direction with a signal.
The CD button enables the CD or MP3 disc player mode. AUX and Tape are for external audio devices and cassette tape mode, respectively.
These comments are based on using the remote with the Panasonic SA-PM19. Please add a comment with the specific model of your Panasonic radio if you need additional assistance.
I hope this helps.
May 05, 2013 | Televison & Video
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
I lost the remote control, how can rewind the hsv tape. Thanks.
There should be a rewind button on the front of the main unit (usually indicated by either REW or 2 arrows pointing to the left), this should be next to the fast forward (again indicated by either F-FWD or 2 arrows pointing to the right) as well as PLAY and STOP - for the VCR. The only thing you would need the remote for is to set the clock and/or perform setup for the DVD player as well as timer recording. Try a universal remote which will make fast forward, play, stop, record (to VHS) and rewind easier.
Apr 11, 2011 | JVC DR-MV7 DVD Recorder/VCR
How do u set the clock in a 1998 Ford Expedition?
push the clock button with the radio off and key on,then hit the fast forward and rewind to adjust the time
Aug 17, 2009 | 1998 Ford Expedition
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Programming a URC22B universal remote controller
QUICK SEARCH
Turn device on
Press and hold [SET] button, then press and release DEVICE button eg tv, vcr , sat, aux
release [set] point the remote at device and pres [POWER] or [PLAY]
until device turns off or plays
Press [ DEVICE] to lock up the code
check other buttons
Nov 17, 2007 | Jensen JR500 Remote Control
Jensen JR500 Remote Control Logo
344 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
