Question about valve. thermostat vacuum. century
Where is the thermostat on Buick century - valve. thermostat vacuum. century
  • 39 Answers
It is probably going to depend on the year, and engine. For the most part, follow the top radiator hose from the radiator to where it attaches to the engine. Usually, the housing that it attaches to contains the thermostat.
Posted on Oct 24, 2013
I Can Not Find The Thermostat On My 1998 Buick Century. Any Suggestions?
Locate the upper radiator hose. Follow it to the engine. Before it meets the engine, you'll notice that its clamped to a metal housing, usually mounted with 3 ten-millimeter bolts. This is the thermostat housing. Remove when engine is cool. Thermostat is inside. Remove old thermostat and replace ensuring the rubber o-ring aroung the outside of the thermostat if equipped. Good luck.
Sep 19, 2011 | 1998 Buick Century
How long should it take to replace a thermostat on a buick centry 2002 3.6L
the 2002 buick century does not have a 3.6L V6 it has a 3.1L V6 in order to replace the thermostat you have to remove the exaust crossover pipe the book time is 2.4 hours so it is a pretty good job...good luck
Jul 16, 2011 | 2002 Buick Century
Where is the thermostat located on a 1986 buick century? An illustration would help!
A 1986 century, you forgot to list then engine size so i will guess its a v6 engine, if its a four cylinder just follow the top radiator hose to the engine and the same goes for the v6 engine, the housing that the top hose clamps to at the engine is where the thermostat is locted,
Jan 08, 2011 | 1986 Buick Century
I. Hput a thermastat in a 1995 buick century .
thermostat spring goes the towards engine away from hose,. hope this helps send your feeback thansk
Aug 02, 2010 | 1995 Buick Century
Thermostat location on 1990 buick century
Find the thermostat on all vehicles like this:
The engine end of the upper radiator hose goes over a pipe stub, or nipple, and then has a hose clamp tightened around it to hold it on that part. That part is a housing, bolted to the engine, and the thermostat is under that housing.
Jun 27, 2010 | 1990 Buick Century
How to change a thermostat on a 95 buick century 6c
follow your top radiator hose to top of the engine, where it hooks up with a hose clamp. under that metal housing is your thermostat! usually 2 or 3 bolts you remove , then lift off the metal housing and take out your old thermostat and remove the old gasket with a razor blade.. install your new thermostat and gasket and away you go!! richie
Nov 03, 2009 | 1995 Buick Century
Where is the thermostat on my 1996 buick century?
Follow the UPPER RADIATOR HOSE from the radiator to wherever it leads to. Under the end of that hose and thermostat housing.is the thermostat.
Mar 28, 2009 | 1996 Buick Century
1999 Buick Century thermostat question.
patience , and a 13 MM wrench , you gotta get your arms in there deep , that lower bolt does not need to come all the way off , the thermostat housing has a slot at the bottom for easier access , loosen it about 3.4 of the way and you can get the housing out , experience says a premium thermostat will give you grief trying to reinstall , get a regular duty thermostat .reverse procedure.
Jan 02, 2009 | 1998 Buick Century
valve. thermostat vacuum. century Logo
Top Buick Vehicle Parts & Accessories Experts
Marc Taylor
Thomas Perkins
Thomas Perkins
Jeff Turcotte
Jeff Turcotte
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
