I interupted drying cycle to remove items, proptly forgot , and instead of putting more stuff into dry i switched on a new prog to wash ,,now nothing is working except for the woed STOP flashing
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
You
should wash your futon cover separately from other items. You need to ensure there is room in the
machine for it. Avoid using detergents
containing bleach. Wash the cover using
the cold wash/cold rinse cycle (unless label inscription suggests
otherwise). After the wash cycle is
complete, you can put the cover in the dryer and tumble dry on a low-heat
setting. I like to remove the cover
halfway through the drying cycle to flip it to ensure that it dries evenly.
Hi dear.Here is some help from the user manual.I hope that helps.Thanks.
DryingRack To use the drying rack Do not remove the lint screen. 1. Open dryer door.
2. Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3. Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4. Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
The delicate cycle is for damp, not wet delicate items. It is more warm air then hot and will not dry wet items forsay. If you have delicate items that need more drying try putting them inside a pillow case and tying the end closed long with a higher setting. Works great with stuffed toys too
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
