How do i connect my single subwoofer out to left,right sub in
    Sergeant:
  • 344 Answers
With a Y Adaper,
Posted on Nov 29, 2012
robotek
  • 1512 Answers
SOURCE: Hook-Up for Paradagim Subwoofer-SB-100
Just use the left input on the sub. The sub frequency components are generally across both channels, the left and right are to allow for easier integration with systems that have no specific sub output, a low pass filter is applied to the audio, left and right get mixed, and then feed to the subs internal amp. I advise for performance to use line level(low level-NOT speaker) inputs wherever possible. If you have any other questions, I am here to help ya. A "FixYa"rating would help my profile. Thanks.
Happy listening
regards
Graeme
Posted on Feb 12, 2008
PyroPCMan
  • 405 Answers
SOURCE: SUBWOOFER output
Just purchase a Y-adapter
http://www.radioshack.com/product/index.jsp?productId=2455299&cp=&sr=1&origkw=rca+y+adapter&kw=rca+y+adapter&parentPage=search
Hope this helps
Posted on Mar 12, 2008
SOURCE: very low ouput from subwoofer preout
Onkyo to Onkyo, sub/receiver, problem fixed by inceasing volume on receiver. Seems the sub audio input does not pick up LF's below a certain output level from the receiver. So, guess I have to live with that. I only hope my nieghbor in the apartment below me can too!
Posted on Apr 29, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
proton77
  • 1183 Answers
SOURCE: broken connector in subwoofer connection on receiver
As per the user manual , the receiver has only one sub-woofer connector. The other alternative is to use the digital audio output for the speakers . That would mean either you have to change the speakers or get a conversion box that would connect your analog speakers to the digital output.
The other thing that can be done is to replace the sub-woofer connector. The same can be done by a radio repair guy or you can take it an authorised pioneer repair centre.
Thanks
proton
source:http://hometheater.about.com/od/avreceiversreviews/gr/piovsx91txhs.htm
Posted on Jul 27, 2008
Im trying to hook up a paradigm pdr-12 to my tv and xbox 360 and need an idea of how to do this the right way so it only plays the bass and nothing else
Hello there this subwoofer has a built in crossover variable from 50hz to 150hz which means that any signal you feed it the sub it will ignore anything but bass anyway.
As for the connection it is made quite difficult if you don't already have an amplifier powering your other speakers, usually home cinema amplifiers have a low level pre out for subwoofers, for which you would just need a phono to phono cable.
However if it doesn't and you have any type of amplifier with at least 2 separate left and right speakers you can connect the wires from these into the subwoofer and it will output the bass from these 2 channels.
Another option is to use a mono to stereo (2 to 1) phono cable where the 2 connectors at one end connect to a tape or record output on your amplifier and the single phono at the other connects to the subwoofer, the same would go if you have a red & white phono (RCA) output on your TV you could also use this to power the sub, in the worst case scenario you could use a single to single phono or rca cable to connect one of the output channels (left or right) on your TV to the subwoofer however this would mean that the subwoofer would only output bass from either the left or right channel.
Hope this helps
Kind Regards
Ant
Aug 26, 2011 | Audio Players & Recorders
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
I do not know how to connect the woofer KEF PSW3500 to the amplifier Denon 4310. BCC sold me a 1 on 1 plug, but the woofer needed to plugs (left and right).
Bass is mono directional in the main,and while your sub has a left and right input ( because a few amps do have left and right sub outs) only one of them is required (usually marked as MONO on the sub). You can also get a Y splitter phono adapter and connect the single cable you have to both sockets, which is how I have mine set up. This is most common
Dec 03, 2010 | KEF Audio PSW3500 Subwoofer
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Feb 27, 2009 | Bose 151SE Main / Stereo Speaker
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
Connecting my subwoofer
got manual on speaker?the reason y some subs have left and rt. is bcause some equipment dont have sub output channel.most sub left channel is usuallly dedicate toe the lfe,which is for the sub output.try it with a splitter and single see if you lose so bass drops when in single,if so then go double .but i think its the left channel.you wont damage anything by conecting a splitter,tet in low volumes ,.but try to get the manual from company or contact them atleast.
Jan 22, 2008 | Signet SP-100II Speaker
 Grubhead
Grubhead
