Question about Canon Pixma iP2600 Photo InkJet Printer
Thinking of buying this printer!
How many ink cartridges does this printer take ... 1 each or 2 or both black and color ???
    Novelist:
  • 180 Answers
This printer will require 2 different cartridges. 1 Black Ink tank - Canon PG-37 and 1 Color Ink tank - Canon CL-38. It will come with those already in it but most people don't know that they aren't completely filled from the factory. You might get about 1/3 of it to get you started and you'll quickly need to buy a refill so you might as well get it while you're there. You should also keep the top of each box in your wallet for easy reference next time you have to repurchase the ink. Finally, a caveat- with inkjet (as opposed to laser toner) it's use it or lose it as they will dry out over a few months even if not used.
Please rate this solution accordingly! Thanks and keep Fixya.com in mind with any future questions.
Posted on Jan 10, 2009
Should I buy printer cartridge or not?
If you do not have a user manual for this printer then download one from this site. It should explain which ink cartridges types to buy and how to replace these. There are only two cartridges but based on the size you can buy different.
HP 662 Black Ink Cartridge (~120 pages);
HP 662 Tri-color Ink Cartridge (~100pages);
HP 662XL Black Ink Cartridge (~360 pages);
HP 662XL Tri-color Ink(~330 pages)
http://h10032.www1.hp.com/ctg/Manual/c03847745.pdf
Aug 05, 2014 | HP DeskJet Office Equipment & Supplies
Poor print quality and I don't think it's the ink cartridge
TRY TO ADJUST THE MANAGE COLOR LOCATING ON YOUR COMPUTER FIND IT AND ADJUST THE DARK COLOR
Dec 02, 2009 | HP PSC 1410 All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Why are only black and yellow printing?
The printer has two ink-cartridges: black and tri-color.
The black cartridge has ink left.
The tri-color cartridge has run out of 2 of the 3 colours of ink.
Buy a replacement tri-color cartridge,
and responsibly recycle the "empty" cartridge.
Nov 19, 2009 | Canon i9100 InkJet Photo Printer
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
color cartridge.
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Won't print with just black ink cartridge
A part solution is print/properties/maintenance/ink cartridge settings/select black only.
You do initially have to buy another color cartridge but you won'thave to buy another expensive color cartridge again in the future.
I
Nov 13, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
51 people viewed this question
old marine
old marine
