How we can use rca rs2620 - Audio Players & Recorders
  • Audio Player... Master
  • 1,267 Answers
The question is too vague and unit is said to be a shelf system so when you play something you should get audio out of it right way. Start with the radio- get audio in the speakers then move on to less likely items of failure like the CD player and then cassette if it has one. Systems with everything inside one box are known by everyone to be hard to work on and costly to keep working due to many break downs. They are designed to go 3-4 years and then be replaced.
Posted on Dec 06, 2012
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
Don't have a manual for Model RS2620 - can't get the clock to stop blinking. Ser # 304103126. Where would I get instructions for the clock?
Hello pjabfalter, You can find your manual at the following link: Please post a reply if this was not the manual you were looking for. Thank you for using FixYa!!
Edward
Aug 24, 2010 | RCA RS2620 CD Shelf System
What are the volt fuses for RCA RS2620? I mean like 150 volts fuses or 200 0r 250?
That would depend on the mains supply of the unit in question. If it has a 250 volt mains supply use a 250 volt fuse. However the crucial one is the amp rating. If it was a 300ma fuse installed a fuse no greater than that should be used. If it was a 2amp fuse a 1.5 could be used, but not a 2.5. Many fuses are fitted with a 250 volt rating in areas where it would never go higher than say 50 volts, such as in the secondary winding of the transformer.
Jul 01, 2010 | RCA RS2620 Single Cassette Deck
My RCA RS2620 has a shorted D820 and a burned R886. Can anyone recomend replacements / know the value of R 886 or have a schematic of this unit?
hi rnollett,
I just plugged my cousins RCA RS2620 into 220volt mains and burned the transformer because its originally 110 volt rating from canada. If you could please test your units transformer output voltages of RED-BLACK-RED wires so I can tell the technician to rewind the transformer usable to 220volt mains, he is asking me those output voltages and I dont have a clue.
Regarding your D820 and R886 if you have'nt yet found suitable replacements, in return, I will check the values of those parts here and I will send it to you.
Many thanks in advance.
Jun 11, 2010 | RCA RS2620 Single Cassette Deck
Hi, I have a RS2620 and the Casette belt is broken... where can I find the casette belt? Help
All you have to do is measure the diameter of the belt (in mm) and the put that and Cassette belt into Google. If you live in the UK Maplin have a range of them.
Jun 05, 2010 | RCA RS2620 Single Cassette Deck
RCA RS2620 - CD works well ocassionally and then not at all
Simple solution - a CD lens cleaner did the job. $11
Feb 19, 2009 | RCA RS2620 Single Cassette Deck
Cannot set the time, need manual for our RCA RS2620 system
hold in the "clock" button until the hour flashes
use the forward & back buttons for the cd player to set the hour. (located just to the right of the equalizer" button)
once the hour is set, press the "clock" button until minutes are flashing.
use the forward & back buttons for the cd player to set the minute.
once done, press the "prog.set" button below the forward & back buttons
Dec 31, 2008 | RCA RS2620 CD Shelf System
RCA RS 2620
Re-state problem please
Mar 18, 2008 | RCA RS2620 Single Cassette Deck
23 people viewed this question
 Grubhead
Grubhead
