Question about Pioneer DEH-1700 CD Player
LOST THE PLUG FOR MY STEREO
MY CAR WAS BROKEDOWN AT A FRIENDS HOUSE I ASKED HIM TO PULL MY STEREO OUT WHILE IT IS THERE AND HE REMOVED THE WHOLE THING INSTEAD OF UNPLUGGING IT AND NOW HE CANT FIND THE PLUG I NEED A DIAGRAM SHOWING WHAT PIN IS WHAT WIRE IN THE PLUG
I went to crutchfield.com and they had a diagram of the plug and what each pin was for.
Posted on Jan 11, 2009
How to remove visonik vcd51 head unit from car dashboard
This usually involves removing the plastic bezel around the stereo. Sometimes these plastic bezels hold some buttons for air conditioning and heat, as well as the hazard lights button. These plastic bezels usually are just snapped in with metal clips on the back of them. You can pry them outward and with a good yank they will pop out. Once you have the plastic bezel around the radio removed, there will be 2-4 screws on the sides, or top and bottom. Once you remove those, the whole radio will pull right out of the dash. Then you have to un-clip the wire harness from the car, and unplug the antenna cable. If you plan on putting a different stereo in the car, KEEP the mounting bracket around the stereo, as well as the "wiring harness" that was used to plug into the vehicle harness. That will save you about $50 in parts to put a new stereo in.
Aug 23, 2016 | Visonik Car Audio & Video
Transmission Fluid Pressure Sensor/Switch
Not so baffling given that Chrysler has major issues with TCM units. Reset the whole thing with a power disconnect and see what it does.
Jul 08, 2017 | Chrysler PT Cruiser Cars & Trucks
My g6 2007 does not have the original stereo harness. Where can I buy one to install it myself so i can add a aftermarket stereo?
I would call all of the salvage yards until you are able to locate one where they have your car. Best to start as close to home as possible because you are likely going to have to go and pull it off. The Dallas County Auto Salvage yard on MacArthur will pull it for you, all you got to do is pick it up. They may mail it. I am not for sure about the mail thing though.
Feb 13, 2011 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
Can you put a newer radio in a 2001 yukon
Hi, my research indicates you can install a single din aftermarket head unit in the 2001 Yukon.
A couple of good websites to use are crutchfield and modifiedlife.
Crutchfields will identify exactly what adapters are needed, and modified life has the factory wire colors.
You will need an adapter to fill the space between the aftermarket stereo and the hole left by removing the factory head unit.
You will also need an antenna plug adapter.
I recommend you buy the wire harness pigtail to simplify the installation--this may or may not include the antenna plug adapter.
If you have onstar, you will need an additional adapter.
If you have steering wheel controls, you will need another adapter to keep those.
Keep the above things in mind when selecting a new aftermarket stereo, as you will need one that is compatible with steering wheel controls and onstar, if you have either of those and want them to continue to work with the new stereo.
Crutchfield has an link called "outfit my car" that takes you through a "Turbo tax" style questionaire and tells you what will work and what you will need. here is the link: http://www.crutchfield.com/App/Car/outfitmycar/MyCar.aspx
Assuming you have a base Yukon, here are your factory wire colors from modifiedlife.com:
2001 GMC Yukon Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Please let me know if you have questions, and thanks for using FixYa.
Jan 18, 2011 | 2001 GMC Yukon
My clarion CD player in my Nissan Primera P12 2004 will not eject the discs can this be rectified and would it be expensive.
Hi.
Check first that it is not a single disk stuck inside.
Try pressing repeatedly the eject button on the on dash player while at the same time you start the stereo.
If that does not work you can try disconnecting the car battery to reset the unit, and then attempt again the procedure above.
Remember that you may be asked stereo code after disconnecting battery, have it ready.
If still no luck, then the unit must be removed from the dash to be taken apart, so to remove the stuck disk.
In that case the repair may require replacement of CD drive unit or front panel. When disk does not exject repair done from a local technician may be expensive. Usually better replacing the whole stereo unit.
Regards.
PS: Here the procedure above illustrated in detail. The procedure is described for home DVD players, but it is the same on any optical unit, including in-dash stereo. Naturally , since the unit is an in-car system, you do not have power cord, but you will need to disconnect battery to reset the system: player system won't eject disk.
Mar 16, 2010 | Clarion Car Audio & Video
I need to remove my Pioneer DEH-1100 from my 1996 Honda Civic. All I can figure out is how to remove the front panel, but I need remove the whole thing and put in a new one. Please help. Thank you.
hi afetr you have removed the front panel look on either side of the stereo there will be a slot on either side, you will need to purchase "radio keys" for the type of radio you have from a good auto store you can buy them off the shelf, you insert either key into the slots on the sides and then pulling them in slightly pull the radio at the same time ( if you just pull straight you will only pull the key's out so bend them in slightly as you pull ) it should come straight out of the security cage....hope this helped
Feb 18, 2010 | Pioneer DEH-1100 CD Player
Hyundai stereo
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 20, 2009 | 1999 Hyundai Accent
I cant access my yahoo email account: i opened it almost 7 years ago and if i lose it i'm worried about all the contacts i wont get back. The thing is: ''for your security'' yahoo ask you to answer a...
Always print a list of your contacts. I have done this several times. But by the time you have fixed your e-mail, your contacts may have changed or moved or lost them to moving of lost friendships.
This happens also,
"Make new friends, but keep the old, one is silver and the other gold.
Some people throw away old friends????
I like to answer some of these when I have a chance.
I need someone to help me in my house and I have asked many people but cannot find anyone.
I have had both hips replaced and cannot do as I used to. I do not have much money to pay anyone and that is the problem also.
I cry for help in my townhouse. No one hears me.
Rita
Jun 22, 2009 | Yahoo Mail
Need an operating manual
I asked my brother and he asked me if any of your friends have got one
If not send me an email at adiktopoulos@yahoo.gr
Mar 09, 2009 | Logitech Pure-Fi Dream Speaker Remote...
Pioneer DEH-1700 CD Player Logo
150 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
