Question about New Bright 181 Toy Christmas Train
I have an older TimberWolf &Redwood train set. Where do you cut the train on? i have placed new batteries in the coal car,n still willl not cut 0n
4 Suggested Answers
  • 5 Answers
SOURCE: New Bright Model #183 - how do I make the train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Posted on Dec 24, 2009
  • 5 Answers
SOURCE: locomotive won't come on
SOURCE: I bought a New Bright Timber Wolf & Redwood
It's supposed to be silver metal with a hole in it.
Posted on Jun 04, 2011
New brite silver rail express
I can find no camera with this description - please can you tell us the make and model ?
Jan 06, 2018 | Toys
Locomotive no longer smokes
If the smoke unit was working, and no longer does, it may be burned out. Did you turn the unit off after running it out of fluid? If not, it will need to be replaced. The switch is behind the smokke box door on the front of the boiler. I'm not sure if the smoke unit is a warranty replacement part, but a check with Bachmann Parts & Services & they will give you an answer.
http://www.bachmanntrains.com/home-usa/prod_serv.php
Your Locomotive is commonly called the Bumble Bee.
Jan 14, 2012 | Bachmann G-gauge Big Hauler - Ebt Boxcar...
Are transformers for the 387 and 384 interchangable?
Check the output of the transformer going INTO the controler. Mine is 19VAC. IF the controler is working you should measure 25VDC between the inner and outer track with the controller switched on. If you have the AC but not the DC voltage push the red reset button. Once you have the 25VDC put your train in place (engine and coal car) and it should run.
Dec 12, 2011 | New Bright 384 Holiday Express Animated...
Purchased a Lionel New York Central Flyer Operating Freight Expansion Pack with a coal dumper. My set runs on O-gauge track, not fas track, but the magnet operation appears to be the same. The coal...
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
Apr 22, 2011 | Lionel New York Central Flyer
I have a holiday train No. 181 which did not come with instructions. I can not locate where the batteries go can you send me instructions?
The batteries go in the first car following the lokomotive, the coal tender. There is a small black knob with a ****. Turn it, and it will open the top part, so you can put the batteries in. This train set will not take a rechargeable battery. Bummer...
Dec 09, 2010 | New Bright 181 Toy Christmas Train
Scientific Toys train won't run
WELL WHERE EVER YOU BOUT IT FROM YOU SHOULD TRY TAKING IT BACK THERE AND GETTING THEM TO LOOK AT IT,TAKE IT TO THE SHOP,OR BUY A NEW ONE. :)
Dec 25, 2009 | Scientific Toys North Pole Express Xmas...
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
Dec 04, 2009 | Lionel 11000 Holiday Tradition Express...
New Bright 181 Toy Christmas Train Logo
553 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
