Question about Samsung LN-S2651D 26 in. LCD Television
What looks like water marks
I have what looks like water marks behind the glass screen in the front off my LCD TV. Is there any way this glass can be removed and cleaned?
  • wsando63 Jan 10, 2009
    the marks are on the back of the screen against the LCD panel
    Brigadier General:
  • 5,158 Answers
Ginko makes a good point... was that monitor dropped or struck with something recently ?
Robert
Posted on Jan 10, 2009
  • Samsung Master
  • 19,396 Answers
If the liquid is dark, and you have dark stains, than it is LCD fluid, and you need to replace display panel.
If instead you have water behind the front panel, then the monitor must be taken apart, starting from the back panel, then boards must be removed and lastly, the LCD panel.
When you have only the empty monitor chassis, with the protective plexyglass panel accessible then you can dry it up.
The unit must be taken apart completely to do the job, amd must be done by an experienced technician, if you dont want to risk breaking a ribbon cable, or damaging an internal part.
  • Ginko
    Ginko Jan 10, 2009
    Evidently some of the poster here does not have a clue.
    As I told you, a complete service to dry the monitor must be done by a technician.
    If you do not care about potentially damaging the unit, you can Remove the back panel, and without removing the digital control board and the rest, just blow cold (not hot ) air , using an hair dryer from distance, not to damage components. Then leave the unit apart in a dry warm place for two or three days.
    This is not the professional way to do the job, but if water inside is not too much , it may work.
    Having the job done by a technician is always better.
    Good luck.
    Genius:
  • 1,550 Answers
Yes you can remove the panel to clean it once you are technical sound in handling the electronic items . Else it is better to call service person to repair it .
    Sergeant:
  • 431 Answers
Unscrew the case or use industrial sprite to clean it
  • nematics
    nematics Jan 10, 2009
    i hope it due to the damage of the lcd i needs to be replaced it cannot be cleaned i is due to pressing hard in the surface of the lcd
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
Tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 | Televison & Video
What is the best to use to clean fingerprints on the screen? Soap and water or glass cleaner?
I always suggest Monster Screen cleaner, It is not alcohol based and is designed for cleaning LCD screens. I use this professionally in my tv shop, this stuff is great, even removes crayon marks.
http://www.youtube.com/watch?v=523NZbh_Qpo check out this guys review.
Aug 03, 2011 | Philips 32PFL3505D 32 in LCD TV
I have a 60" sony projection TV (2005 mod.). I need to know how to take off the front screen (glass) of the TV so I can clean the inside that has gotten dusty.
U can't take out screen,it screws in as part of the LCD screen.Just take a soft cotton cloth,soap it with some water rinse it,gently clean ur LCD screen.
Apr 01, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My Sony KDE42xs955 was cleaned with windex and now has water marks on the screen that I cannot get off is there a trick to removing these? They look like the marks left on a windshield after going through...
Assuming you have removed the coating with the cleaner, (TV is much brighter where the marks are)
If you have home insurance then now is the time to call.
The TV, being an LCD, has a coating on the front, kind of like paint, but not. It is what allows an LCD TV to produce "Black", by blocking the light.
It is not easily replaceable as it is sprayed on at the factory.
Sorry.
Sep 07, 2009 | Sony Televison & Video
My son threw a ball and hit the screen cracks all over can this be fixed with a new screen or is it junk now really bright light shows through all the crack marks
The front glass is just a protector for the LCD screen. If your TV turns on and the picture looks ok (may be a little color variation around the crack if front glass is pushing on it, variation OK black Bad) If the picture looks within the range described then replace the glass. It is just a piece of standard glass and a pretty easy diy job. If the LCD screen is broken the repair will be more than the replacement cost. Sad fact US TV repairmen make a living wage while the workers that assembled you TV wouldn't be able to buy lunch here with what they made putting it together.
Jun 02, 2009 | Toshiba 42HL67 42 in. LCD Television
Water marks and dust on the INSIDE of Nokia 6085 LCD screen
Brother Frist Time I Am Faseing Problem Like This Its Unbelievable, Go 2 service Senter & Chaque Handset For Other Dameges.
Mar 31, 2009 | Nokia 6085 Cellular Phone
Cleaning the screen
Try hot soapy water, since a flat screen TV should be glass.
Feb 11, 2009 | Televison & Video
HELP!!!! - Vizio GV47LF LCD HDTV HELP!!! - HOW TO FIX?
When you turn it in, do you get an image? And if it is the LCD screen ( not the front protected glass) then yeah you might as well junk the TV. The cost for a replacement LCD screen exceed the cost of the unit. Sorry about the bad news, just being honest. Turn the television, if the LCD is cracked, then you will see it right away when the television is turned on.
Nov 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Samsung LN-S2651D 26 in. LCD Television Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
