Question about IBM eServer xSeries 206
Cant install new operating systems from USB or CD and have RAM Issues.
The USB ports does work and the CD drive come out. But when i want either try to boot Ubuntu Server 12.04 installer from a USB or CD it just boots the already installed Windows server 2k3. It came with 2x1gb RAM cards and when i boot normally it starts to check the 2gb RAM but then fails and reboot and show theres only plugged in 1,5gb RAM and then tries to check them but fails and reboots and only show 1gb RAM but then checks it and run normally.
  •  Bjarke Almer Frederiksen
    Right now i cant boot at all because i changed unplugged the CPU (Pentium 4 3ghz) and when i put it back and turns it on the fans are running wild and the computer wont boot. Maybe the CPU or the mobo?.
  • 2,878 Answers
And you changed and saved new boot order in BIOS?
You may have a bad DIMM. Test one card, one slot at a time till you identify the bad one.
Posted on Nov 27, 2012
    Right now i cant test it because i changed unplugged the CPU (Pentium 4 3ghz) and when i put it back and turns it on the fans are running wild and the computer wont boot.
3 Suggested Answers
  • 32 Answers
SOURCE: I have an ibm x365 series server with windows
Have you created the partition?
Posted on Jun 01, 2010
JAIN_IT
  • 73 Answers
SOURCE: when iam try to install windows 2003 server in ibm
Please chack your cable connections .
http://webcache.googleusercontent.com/search?q=cache:wVeOJoYR170J:www.techspot.com/vb/topic127298.html+no+hard+disk+drive+detected+in+the+server&cd=3&hl=en&ct=clnk&gl=in
try this link.
JAIN_IT {INDIA}
Posted on Sep 18, 2010
I HAVE DELL LATITUDE D600 but the usb is not working.. power also not coming..i cant charge my phone also by using those USB port....Please tell what to do??
Your USB ports on your Dell computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
To Run a Diagnostic Test on your USB Port
Dell has an online diagnostic tool to help identify and fix issues with your system.
  1. Go to theDell PC Diagnosticpage
  2. UnderChoose a Diagnostic Type, selectHardware.
  3. Using the scroll bar on the right-hand side of the window below, locate the listing for USB.
  4. SelectUSB.
  5. ClickRun Diagnostics.
  6. Agreeto Terms and Conditions in Legal Statement.
  7. Follow the instructions to test each USB port.
Jan 05, 2015 | Dell Computers & Internet
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
Computer won't recognize the store-it drive external hard drive
You may have a problem with your drive or the usb ports so we need to check both. The green light usually just means the device is getting power.
The first thing to do is unplug the drive and reboot the computer. Make sur eit has finished booting up completely. Then plug it into a different usb port NOT the same one. If it detects and works it was just the operating system or motherboard not recognizing whats called a legacy usb device.
Next we want to try a different usb device in the computer to make sure the ports are working.
And we want to try the drive in another computer to make sure it is working.
At this point you will know if the problem is your drive or the port. If it is the drive you can get it runnning again sometimes by taking the actual drive out an dputting it into a new external drive enclosure kit.
Jul 09, 2009 | Pexagon Store-It 80 GB USB Hard Drive
My pc won't detect my printer, my printer is brother dcp 150-c
have you connected the printer's USB port to your CPU? If not, then do so. If after doing it, still your PC don't detect your printer, make sure you have a functional USB port. To check it, try using a USB Flash drive if it works with your PC. If it won't, you might have to "Enable" your USB at your BIOS.
Regards!
Jul 09, 2009 | Office Equipment & Supplies
My operating system has been restored and hard drive replaced.my USB ports are no t operating
If you have CD utility enclosed onto your computer then you to insert it to the cd room and then install the driver about usb or install all the drivers so that the system work to high performance.
try also to test the usb port maybe not functioning at all. its either damage port or loss connection.
may this help,
melnavz
Sep 17, 2008 | Gateway Computers & Internet
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Usb ports
Make sure that USB ports are enabled in your PC.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Device manager/USB problem?
To get your camcorder to work properly with your PC (and show up in Device Manager), you must install the software (the driver and editing software) that came with your camcorder. Your system also must meet the following minimum requirements: * CPU : Intel® Pentium III 450MHz processor compatible or better * Operating system : Windows® 98SE/ME/ 2000/XP * RAM : 128 MB or more * CD-ROM: 4x CD-ROM drive * VIDEO : 65,000-color or better video display card * Available USB port * Hard Disc : 4GB (8GB recommended) If the camcorder is still not being recognized after you have installed the software, reboot your computer, and then try another USB port or another USB cable. If your problem persists, contact Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Be sure to have the model number of your camcorder handy and basic information about your PC such as operating system, kind of CPU, and available memory.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
IBM eServer xSeries 206 Logo
342 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
