Question about Refrigerators
Daewoo drs30dsmb freezer top half not working
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Nov 28, 2012
I need a wiring diagram for a Daewoo fridge/ freezer frg 1820brw, any idea where I can get one?
check repairclinic.com - they have a lot of repair info, some online, as well as some repair videos.
Nov 26, 2014 | Daewoo FRG1820BRW White Top Mount...
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Daewoo frsu201ai side by side fridge/freezer The top shelf of my freezer isn't working and the fan doesn't seem to be moving???
If the fan is defective, it will cause your problem (top not freezing but lower half ok) but could also be a defective thermostat, defrost cycle, compressor and more, which may produce other symptoms such as leaks of defrost water on floor in front or other warning lights.. First, double check that the fan it is not working by holding in the light switch, as the fan switches off each time you open the door. You may want to remove the back panels behind the ice maker, to check that the plug and wiring is ok, before purchasing a replacement If you still think it is defective, it can be replaced easily by someone with average to good DIY. It is pretty cheap to purchase a replacement on line and takes about 20 minutes to install, so Insulated well frozen food should keep ok during work.
May 20, 2014 | Refrigerators
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
Water not filling the ice tray
locate the water fill valve,wiggle the connections to it as to clean these connections,then manually fill the ice maker with approximately 4 oz. of water,sometimes this will kick start the ice maker and it may take over from there
Jan 31, 2013 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Daewoo frs-U2OIC top shelf freezer not freezing
Could be the internal fan at the top of the compartment or its electrical feed is not working. With the door open, hold the light switch in (the fan usually doesn't work when the door is open) and see if it is spinning. If not, it and its connections should be checked
Feb 13, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
My daewoo FRSU20DCB has appeared to stop making ice and the top shelf of the freezer and refridgerator are warm? the plumbing to the unit is still working ie we get water but it does not appear to be going...
i have the same problem and have tried to contact daewoo on a number of occasions but only to be passed onto an engineer who wants to charge me min two hundred pounds
Mar 08, 2011 | Daewoo Freezers
Refrigerators Logo
189 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
