Question about Saeco Odea Giro Plus Coffee Maker
Saeco odea giro motor spins but doesnt grind
The grinding motor will spin, but nothing grinds . Then it squirts out only hot water ?? pls help
SOURCE: Saeco Odea Giro - disassembly
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
Posted on Aug 26, 2009
SOURCE: Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Posted on Nov 24, 2009
  • 55 Answers
SOURCE: We have a Saeco Odea Giro coffe machine, and it
check the screens in he brew group to make sure they are clean and clear also under the top screen theres a small hole make sure that is clear also
Posted on Dec 18, 2009
  • 81 Answers
SOURCE: saeco odea giro is not grinding enough coffee..
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Posted on Jun 19, 2010
EsWorld
  • 1618 Answers
SOURCE: Our Odea Giro Plus grinds
Sounds like the screen on the brew unit is blocked or the grind is too fine.
Posted on Sep 15, 2010
Saeco grinder
Maybe the piece that direct cofee to brew group it is missing, so all cofee fall down.
Oct 04, 2013 | Coffee Makers & Espresso Machines
Hi i have a Saeco Odea Giro Plus, that was broken ceramic baked klay. after replace new it have a problem with my Saeco Odea Giro. The problem is that the bean grinder doesnt grind (I only hear sound of...
you need to change this part ,which is under the ceramic knife. You will have to open the coffee grinder and take out the knives and change the holder to the lower knife. That's your problem. This is the product code 149198350
Apr 22, 2017 | Saeco Odea-Giro Espresso Machine
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Talea Giro - Will not grind coffee
Does the spindle spins when you do the grinding? If not the parts in the grinder is broken. If the spindle still spins and you get sort of wood chip grounds, the adjusting wheel has come off the grinder when you adjust the grinder too coarse.You can undo the grinder if you know how to open the machine. Go to my Odea solutions and look up step by step instruction on how to. Itis very similar.All the best.
Jul 11, 2010 | Saeco Talea Giro Espresso Machine
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
The bean grinder doesnt grind, only water comes out
If it is working before, probably the coffee chute is clogged up. You can remove the bean hopper and see where the coffee drop into the brew unit.If the chute is still attached just clean the blockage, if it is broken you will have to remove the grinder and replaced it.
Jan 17, 2010 | Saeco Odea-Giro Espresso Machine
Hi i have a grinder problem with my Saeco Odea Go
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
Sep 10, 2009 | Saeco Odea-Giro Espresso Machine
Saeco Odea Giro Plus Coffee Maker Logo
51 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
