Question about Car Audio & Video
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Posted on Jul 18, 2013
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
  • 14 Answers
SOURCE: need wiring diagram
This is a general wiring diagram for most head units.
Should be what you're looking for.
Posted on Dec 17, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
dj x
  • 61 Answers
SOURCE: every time i try to hook up my cd player to my
this can be one of three things
1) the fuse on back of CD player could be blown
2) you need to push and hold the src/pwr button till unit powers on
as long as the yellow and red wire are attached to the positive battery wire you are good if the ground is to the battery ground and you try the first two steps i said and nothing happens........
3) ground the black wire from back of the CD player to any metal surface on the golf cart than try the first two steps again
it should power on if this is the case
hope i was able to help you
Posted on Mar 06, 2009
I have a lorex CA1090310741 model MC7540 color camera but the wires are cut.. I need to know which is what their are 4 wires red,white,clear coated copper and bare copper???
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Oct 03, 2017 | Lorex Home Security
5 wire security camera wiring diagram
standard cctv camera wiring
red for + 12v
black for comm
yellow for + v (+video signal)
white for -v (-video)
Jul 09, 2014 | Lorex Corp SG6184S Weatherproof Mini Color...
My wires to my nuvico camera model number cvstd39nl are all busted up trying to connect new ones need help
What colors dobu have black or red is hot all wires will share vommon ground ysually bare or grn or striped yellow is video white is audio if it has audio
May 28, 2014 | Nuvico NVC-CVSTD39NL 1/3 Inch CCD 580TVL...
I have a ccd color camera with a broken cable, the unmatched colors are red, white yellow, black and bare copper. the end line it needs to connect to has red, white, yellow, blue, green and bare copper,...
sorry partner you have a prob. no changing wires will ever work in the corder . try the shopping for systems that are compatible to the tv monitor hook up .. looks like a really nice camera too .
Aug 21, 2013 | Clover Corporation Home Security
Cut wires on bunkhill weatherproof security camera#95914
My bunker hill has a black, white, yellow and green. I am confused with the white. Help
Oct 17, 2012 | Home Security
I need a wiring diagram for soc-n120 camera
1 2 3 4 5 6 Green Red Yellow Bare Gorund Clear
Cover
Black RJ11e color & slot. Orientation Lock Pin Down. Wire at bottom
May 10, 2012 | Samsung Security Color Camera Soc-n120 +...
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
Micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Feb 09, 2010 | Swann Communications DVR4-Pro-Net...
I have an aqua vu scout and it has good battery and connection but no picture
mike if you are still having this problem, i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Dec 23, 2009 | Aqua GPS
Need wireing map for cv67 i have four wires red black yellow white whats what?
Only red(+) Black(-) and Yellow (Video) is used if you just cut off that mini din plug end and were looking at the wires coming from camera. I bought some standard power and bnc pigtails from DX.com and replaced that mini din cable they use to make their connections to a standard cctv type.
Un-screw the main lens cover and you will see a screw ring and by taking a verner caliper to catch on both sides you can unscrew camera unit ring and when you look inside the only wires you need to solder to new pigtail is red/black/yellow each to their own color.
Pushing the pigtail thru may be a little pain but with a little spit on wire makes it a lot easy.
Re-assemble in reverse and you should be up and running.
Camera runs on 12 volt with center of plug positive and video bnc center is video.
Hope this helps.
Sep 28, 2009 | SVAT CV67 Hi-Res Outdoor Weatherproof...
Car Audio & Video Logo
242 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
