Question about Akai Televison & Video
BLUE PROJECTION LAMP WONT WORK - Akai Televison & Video
    Top Expert:
  • Akai Master
  • 14,553 Answers
Either no voltage or crt is bad, one or the other.
Posted on Dec 22, 2012
Tv wont turn on after replacing lamp
there's a blue switch that needs to be actuated when you put the 2 lamp covers on.
Feb 17, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen is black and picture very dark
What did you have before you replaced the lamp?
Dec 07, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Tv wont turn on
The lamp life span is over,need a new projection lamp replacement.This tv lamp has not been replaced at least 1 1/2 or 2 years?The tv lamp in the tv now,tv on an used at least 4 or 5 hours a day too.
Jun 29, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Tv not turning on
Ur tv,projection lamp been use alot about 2 years or more?The lamp must replaced the lamp life span it over.
Apr 05, 2010 | Hitachi 60V500 60" Rear Projection...
Blue light flashing
Possibly the power board or the sustain board has died.
Power board failure does not stop the blue light from working as this is an LED on voltage side of power transformer. The set fails because it has detected a voltage difference in one o0f the other boards that controls the initial starup and convergence. Some transistors and capacitors are also possibly involved. Not a dIY unless you are skilled. Parts $300 labour ?
but about $400
If you are a DIY get a kit from this site, complete with step by step instructions This is an LCD rear projection set.The yellow blob may be from the drivers to the LCD display, dirt or object on the projection mechanism, stain on the mirrors or lamp; bad projection lamp - among others.If you are handy, get inside the set and see if you can observe any of the items mentioned above.
Ploease rate my help++++ Thanks for using FIXYA
Feb 26, 2010 | Televison & Video
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
Samsung HLP5063W Tv
while replacing the color wheel you know you see two cords running from it the blue/white cord and that copper cord. if you replaced both the color wheel and lamp, then it could be that copper cord just switch it around i did that and now my tv works
Jul 15, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
14 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
