Question about Maytag Neptune MAH5500B Front Load Washer
Maytag 4000 washer door unlocks - Maytag Neptune MAH5500B Front Load Washer
    Sergeant:
  • 198 Answers
Try unplugging the unit for 30 mins
Posted on Nov 27, 2012
Maytag Washer 4000 series door not closing ! How to repair
it seems that the door latch assembly may be damaged and needs to be replaced the cost is around $7.00. at www.repairclinic.com.
Nov 10, 2016 | Maytag Washing Machines
How to manually open locked door
First UNPLUG the WASHER.
There is a little white circle plastic lever that feels like an upside down lollipop about 2-3 inches below the door lock behind the front panel.. Pulling that down will unlock the door.
To access from the top of the washer remove 3 screws to the back top of the washer, push it back and then lift the top off the washer. Facing the washer slide your right hand down the space at the front corner where the lock is located. Feel around for the circular part at the bottom of the door lock and gently push it down. The door should then manually click and unlock.
To access from the bottom of the washer. Facing the washer, Remove the 3 screw to the very bottom that is holding the small access panel in place. This allows access to the bottom of the washer. Once removed, reach towards front and upwards to where the door lock is located. Feel around for a circle plastic level. Pull the level down. The door should click and you should be able to open the door.
Apr 18, 2014 | Maytag Washing Machines
Maytag 4000 series won't open
unplug it for a few minutes, then plug it back in.
Read more: http://forum.appliancepartspros.com/washer-repair/41589-maytag-washer-door-lock-wont-unlock.html#ixzz2qLpqCTvO
Jan 13, 2014 | Washing Machines
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
Maytag 4000 series error code F 29(door unlock error).
Thank you
Jeff Rockwell for trying to help me out.
I did all the step and I replaced it with the new switch/lock that i got for Ebay but still the same problem. I diagnostics using the tech.sheet and still say F 29. Not sure the new switch/lock is bad. How can u test if the new switch/lock is bad?
Dec 20, 2012 | Maytag MAH6700AWW Neptune Front-Load...
I do not get the door lock indication on my maytage neptune frontloader washer, which prevents the high speed spin.
what model is it if its the 3000 or 4000 u have to replace lock latch and top board not worth fixing if its thee 5500 model just the locklatch and its worth fixing
May 20, 2009 | Maytag Neptune Washer
Maytag MAH21pddww door locked
hi thanks for the question to unlock the dor manually open the soap door look to the right top inside its a small piece of string pull on it. that should unlock the door thanks the appliance doc
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
