Question about LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1750S has just glowing white screen and no on screen setup menu either.
  • 1,684 Answers
That is a common symptom of a failure of the filter capacitors on the power supply board. When the filter capacitors go out the backlight can get power so there is light but the control board is not powered up so you get no picture. You can rebuild the board and bring the unit back to full working condition by replacing the defective parts. Here is a link to information showing what capacitors you will need to get to do the rebuild.
www.ccl-la.com/catalog/product_info.php?products_id=246
And here is a picture of what the AIP-0108 power supply board looks like
My LG Flatron L1750S has just glowing white screen - 11_28_2012_5_22_24_pm.jpg
I hope this helps,
BuddyMc
Posted on Nov 28, 2012
SOURCE: LG FLatron LE15A10 LCD problem
I installed everything from CD but still hv the problem
Posted on Apr 09, 2008
  • 732 Answers
SOURCE: My LG Flatron L1750S when powered on blinks and
melrosebanjo, Your monitor will need to have some work done on it's "switch-mode-power-supply" and /or "INVERTER" circuit. After you view some vids at YOUTUBE that deal with replacing bad electrolytic filter capacitors and detecting poor quality intermittant solder joints. Search for vids of "LCD monitor repair" "LCD monitor disassembly" !! Learn what are the major causes of LCD BLACK screen problems. Learn the difference between BLACK AND BLANK screens. Read some of my other posts in my profile. then repost with additional comment here on fixya. also visit www.ccl-la.com/badcaps.htm. and www.lcdparts.com
www.badcaps.net FYI Good luck 12fixlouie
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: Flatron L1750S (Silver, Black) 17" LCD Monitor: Out Of Range - what does that mean...
Your PC video resolution is too high for this monitor to display, you need to set your PC video reslotion to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 19, 2010
budmrtn
  • 11361 Answers
SOURCE: lg flatron l1750s screen is
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and all other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 08, 2010
budmrtn
  • 11361 Answers
SOURCE: My LG Flatron L1750S will not come out of "power
Try it with another PC first, if still not working, then start looking at the power supply DC filter caps first.
http://s807.photobucket.com/albums/yy352/budm/LG%20L1751S/
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Aug 31, 2010
My LCD LG L1730S is display white screen not show anything. I check R Fuse(0 Ohm) all OK. What's next check.
Just glowing screen and no on screen setup menu either?
It means that the LCD panel T-CON board (on the LCD panel) is not getting the 5vdc from the logic board or the ribbob cable came loose or it hac blown sruface mounted fuse on the T-CON board.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1730&kategoria=monitor&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 22, 2011 | LG Flatron L1750S 17" LCD Monitor
LG Flatron screen out the writing power save mode and then only a black screen please give solution thankz
I have a power save problem, a capacitor causes it where can I found the capacitor on the power circuit?
Jan 20, 2011 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
Calibration
Have you tried adjusting the "Adobe Gamma" via the setup from your control panel?
Oct 12, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
574 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
