What convergence ic's are used in the Pioneer pro 99?
Was it the single stk 4277?
  • 2 more comments
  • Robert Jones
    Robert Jones Dec 22, 2012
    Thanks very much for your assistance gentlemen. Great info here. The owner wrote in and ID'd the chips as the STK 392-560s. They have since been upgraded by the 392-570s, which are 3 channels each. There are occasionally 6 channel ICs where the entire workload can be done by 1 IC, like the previously mentioned 4277 and the 393-110. I would be very wary of ever changing out the convergence board for a repair like this, as chances are the eeprom containing all the convergence registers you set uses will be mounted on that board. Starting from scratch is never easy, and if you change out a board with the eeproms on it, you have to start completely over. Tho I can do it, it's never my first choice, as tons of extra work is then required. Mr Bob
  • Robert Jones
    SD Tech: Not all CRT RPTVs use 2 chips. Some use only 1. They all do use 6 channels tho. The STK 392-110s have been upgraded at least 4 generations since they were used as factory issue 12 years ago. The 392-180 is the one I use these days, I would never put in a 110 again, now that it has been eclipsed by its newer stronger and much more recent replacements.
  • SD Tech
    SD Tech Dec 23, 2012
    having replaced over 1000 convergence chips I would disagree, higher current etc does not justify or explain one fact, most of the chips in additon fail for a much simpler reason, the heat transfer mateial or grease as some call it dries out and a device reaches a point where the material actually inhibits the transfer of heat, yes the old Hitachi sets that used 3 individual chips almost never failed but were working much less. , as far as the 110 goes put two in a set properly and put two in another set , the higher current rated ones and play them for years, I bet either will last about the same amount of time depending not so much on current ratings etc but how fast the heat sink compound becomes dry and like old paint on your house. Those chips do not get baked onto the heat sink for no reason.
  • Robert Jones
    Robert Jones Dec 23, 2012
    oh I grant you they get super hot and would not survive at all without the heat sink and its compound achieving sufficient heat transfer. I had not thought about it from that perspective and grant you your point on that. When I describe how to do this job I recommend using a putty knife to get any dried-on heat sink compound offa there. However when it comes to improvements - and I have no idea what the actual upgrades were - I always try to stick to the more improved versions of ICs esp. when it's 12 years after the originals were factory issue.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I doubt that, most use the stk-392-110 but the part number will be right on both chips, it should use two chips.
Posted on Dec 22, 2012
premtech
  • 934 Answers
SOURCE: convergence problem
That unit has a convergence repair kit that should fix most problems. Order it directly from Hitachi p/n# X480295. It contains: Rk42 3.3 Ohm 1w Rk46 1.8 Ohm 1w Rk50 3.3 Ohm 1w Rk54 1.8 Ohm 1w Rk58 3.9 Ohm 1w Rk62 2.2 Ohm 1w Ik04 Stk392-150 Ik05 Stk392-150 And I would strongly recommend testing all the resistors in that circuit for change in value. Are you using a good heat sink compound on the STK's when you installed them? That and ordering the japanese knock-offs for STK's are the two most common critical mistakes made. Originally that unit had two STK392-110's for conv. amps. Even Hitachi recommends subbing to a STK392-150 or 180 for greater reliability. You do realize that for the cost you have after two failed attempts you probably could have taken this to a reputable shop and watching the ball games now. :) (no disrespect intended) Good Luck! Bill
Posted on Jun 01, 2007
SOURCE: convergence ic's
CONVERGENCE PRABBLUM
Posted on Dec 26, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Replaced STK ICs but image is all distorted
Usaly when this happens the little fuses also fry they are 5 amp and located neer the ic's and at the bottom right of each ic, also they are green and look like a restor could check and see if they are open and then check all the big resistor to see if any of those show open, other than that I will paste my standard fix for this set
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Posted on Feb 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Posted on Jul 17, 2008
  • 899 Answers
SOURCE: won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Posted on Nov 05, 2008
My Pioneer PRO-200 60 in. Rear Projection Television picture looks great however it appears to be dark and blacks all blend together on the screen.
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 03, 2010 | Pioneer PRO-200 60" Rear Projection...
My tv looks like it is in 3-d. i went to set-up menu, convergence, the red is off and will not move over to line up. it was fine one minute then it was out of wack the next.
The tv 100% have convergence problems,it dead.The tv convergence board,require changes 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 07, 2010 | Pioneer PRO-620HD 58" Rear Projection...
The color is out on my tv
U mean all ur colors picture lines on the tv are misaligns?Ur tv convergence are dead.This problems are the 2 STK convergence ICS and some or all it resistors are dead.The convergence board the 2 STK Convergence ICS and those resistors must be change to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 18, 2010 | Pioneer SD-532HD5 53" Rear Projection...
Hello\ screen pin cushioning
This is the most common failure on projection TV's regardless of the brand. It is caused by a failure of the convergence circuit. In particular, there are two STK IC chips, sometimes three depending on the model, and these are power amplifiers that drive the convergence yokes. They typically last 5-6 years and then they fail. Sometimes the failed IC will also burn out one or more of the low-ohm feedback resistors near the heat sink. If this is the case and you don't find/replace the burnt resistors, the picture will still not be converged, and within a short time of turning on the set, the new STK pack(s) can be damaged.
Jul 06, 2009 | Pioneer PRO-200 60" Rear Projection...
Colors are skewed on Pioneer Pro-520HD
you can replace your the convergence chips on the convergence board. The board is to identify because it has a large heat sink. The convergence chips normally starts with STK... After you find the chip, you can buy online (ebay has a lot of listing) and costs around $10. If you know how to solder, it is very easy to do. I just replace the convergence chips on myPRO-610HD and it works perfectly.
Feb 20, 2009 | Pioneer PRO-520HD 53" Rear Projection...
Power problem on Pioneer Pro-700HD
The failure is not on the power supply but the convergence amplifiers STK ICs have the 24 volts shorted.
If that fuse is blowing, de-solder the convergence ICs and put a new fuse to power up the TV; you should see distorted video when the TV powers up and the fuse should not blow.
The service manual migth not help much in this case since the failure is easy to pin point.
Good Luck.
Oct 03, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Blue lamp climbs up on a curve from center of screen
convergence sys. Usually they use STK ICs in there, replace them.
Mr Bob
Dec 22, 2007 | Pioneer PRO-700HD 64" Rear Projection...
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pro 99
Sounds like convergence outputs. Possibly some biasing resistors.
Mar 19, 2007 | Pioneer PRO-99 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
