Question about RTO Garden
Stihl chainsaw 201T diagram - RTO Garden
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
SOURCE: how to find date of manufacture for stihl chainsaw
call up Stihl USA and ask them when your saw was manufactured. Tell them you bought it used and give them the serial. They told me!
Posted on May 11, 2010
Parts diagram for a stihl ms 461
the link I attached has a slideshow at the bottom of the page with all the diagrams you should need.
have a nice day :)
https://chainsaw-workshop-manual.com/product/stihl-ms-461-parts-list-manual/
Jul 14, 2017 | Stihl Garden
How do I find a parts manual for a Stihl MS290 ?
You Google pretty much exactly what you wrote and you get this
[PDF]STIHL Chainsaw Illustrated Parts Lists n Workshop Service Manuals thebakeliteradio.com/sawspares.com/Stihl%20MS310%20Service%20Manual.pdf
  1. Cached
  2. Similar
MS 290, MS 310, MS 390. This service manual contains detailed descriptions of all the typical repair and servicing procedures for this power tool. As the design ...
[PDF]STIHL MS 290, 310, 390
en.stihl.ca/p/media/download/en-ca/MS_290.pdf
  1. Similar
Apr 19, 2006 - MS 290, MS 310, MS 390. English. BA_. SE .... Manual. !Warning! Because a chainsaw is a high-speed .... and the function of the parts of your.
Stihl MS 290 STIHL FARM BOSS ' Parts List - ManualOwl.com
https://www.manualowl.com/m/Stihl/MS-290-STIHL-FARM-BOSS/Manual/401004
  1. Cached
  2. Similar
Stihl MS 290 STIHL FARM BOSS ' Parts List - Page 1. STIHL MS 290, 310, 390 A Zylinder MS 290 Cylinder MS 290 Cylindre MS 290 Zylinder MS 310 Cylinder ...
Stihl MS290 Parts List and Diagram : eReplacementParts.com
www.ereplacementparts.com/stihl-ms290-chainsaw-parts-c-162329_162330_182548....
  1. Cached
  2. Similar
Need to fix your MS290 Chainsaw? We have parts, diagrams, accessories and repair advice to make your tool repairs easy.
Stihl MS290 Parts
www.barrettsmallengine.com/stihl/ms290.html
  1. Cached
  2. Similar
Find parts in the Stihl MS290 chainsaw parts list below and find where to purchase them online.
Stihl MS290 Repair manual ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
  1. Cached
  2. Similar
Nov 4, 2008 - 20 posts - ‎18 authors Hi, I am new to this site and was looking for some help on rebuilding an MS290. I have the replacement cylinder and piston but need tips on ...
parts manual for Stihl MS290 Google Search
Dec 18, 2016 | Stihl Garden
Replaced manifold on my 201T stihl chainsaw. How do I get the triggers to the carb?
You can probably see how to do this on you tube sir.
Sep 28, 2014 | Garden
Need a diagram of fuel line system for a 311y chainsaw
http://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/279941-stihl-chainsaw.html#b
  1. Stihl Chainsaw - DoItYourself.com Community Forums
    www.doityourself.com/forum/outdoor.../279941-stihl-chainsaw.html
    Oct 4, 2006 - I am in the process of rebuilding my Stihl chainsaw carb. I am having troubles identifying this Stihl model. The only sticker on the saw is 311Y.
Mar 22, 2014 | Stihl 311y
Need the parts diagram for stihl 012avp chainsaw. Saw was given to me in a box now need the diagram so I can put it back together
Stihl doesn't offer an exploded view of their units and the parts list we have can't be copied or printed
Jan 23, 2013 | Garden
I need a parts diagram for an MS-310 Stihl chainsaw
You can't have one, you're not a STIHL tech, but if you tell me what part you need, I will gladly give you the part number to find.
Jul 06, 2012 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
Stihl ms 250 diagrams
All manuals available at www.stihlusa.com
Mar 01, 2012 | Stihl Garden
Garden Logo
161 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
