Question about Garden
Broken pull cord on model gw-16503 - Garden
2 Suggested Answers
  • 468 Answers
SOURCE: Pull cord broken. After removing red hood and
You don't need to remove the rivets. There should be two metal tabs that bend over the nylon retractor, or it'll have a screw in the middle of the retractor pulley inside the cover. you bend those up a little, or remove the screw, remove the retractor, be careful, because that spring can be fun if it gets away from you, take the old rope out, put the retractor back in place, wind it back as far as you can, feed the rope in, tie the knot, and let it draw the rope in. Put everything back like you found it, and your pull rope if fixed.
Posted on Mar 12, 2010
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
HUSQVARNA 326E PULL CORD WANT TURN SHAFT
could be the pawl catch on the crank shaft is not working properly, if this is an easy start model, there are two springs and two pulleys to inspect. usually second spring is the problem.
Jul 25, 2014 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Ariens 926LE broken pull cord
No you remove the engine cover that the rewind assy is riveted too.
Feb 19, 2014 | Cars & Trucks
Replace broken pull cord
the way i done this was drilling out the rivets,replacing the cord and putting new rivets back in.if you dont have new rivets or the tool to put them in with you can use self tapping screws instead. i hope this helps you out?
Feb 19, 2014 | Garden
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
Apr 04, 2012 | Cub Cadet Garden
Mar 11, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a craftsman model 315 circular saw i have to change power cord where do i put ground wire since it is a 2 prong cord? i have 14-2 gw to replace it with.
If the cord needs replacing because of a defect return it to Sears. Craftman tools are gauranteed virtually forever. I return a circular saw a few years ago agter useing it fo over 5 years and they replaced it, no questions asked.
Jan 30, 2010 | Electrical Supplies
TB144 pull cord does not catch, pulls free--no start
yes exactly what i would do sounds like the springs are either worn or gummed up or just broken on the dog ears
May 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
