Question about Hotpoint Ultima WF860 Front Load Washer
Dryer blowing cold air even though drum is rotating how do i get it to blow warm air as it is supposed to
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 28, 2012
  • 139 Answers
SOURCE: hotpoint aquarius dryer
The t-stats have blown.. these are located on the top of the heater on top of the drum.. To check to see if their blown check the continuity if they are blown then there will be no continuity ... They come in a pair and are easily replaced.. All you have to do is take off the lid...
Posted on Nov 14, 2007
jason0110
  • 66 Answers
SOURCE: creda t601cw condenser dryer
hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Posted on Jun 14, 2008
  • 72 Answers
SOURCE: MY HOTPOINT CONDENSER TUMBLE DRYER NO LONGER HEATS
check the thermal fuse and element the fuse is located on ele housing
Posted on Nov 17, 2009
apart4u
  • 213 Answers
SOURCE: I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Posted on Jan 10, 2010
jcfs259
  • 177 Answers
SOURCE: The dryer is blowing cold
Find your thermal protection switch. It looks like a big round button with two screws holding it on either side. (Make sure your drier is unplugged!) There will be a wire going from it to the heating element. It is what regulates the temperature, so it doesn't overheat. Unplug the wires off it and check across the terminals with an ohm meter. It should have full continuity. If not, it's your problem. Replace it. Easy repair.
Posted on Feb 18, 2011
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
The drum is turning but it's blowing cold air, no hot air not even warm. The last time it was used it was hotter than usual, but now nothing.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 04, 2011 | Dryers
The drum rotates and blows air, but it doesnt blow hot air. I already changed out the thermal fuse.
heatman101
Aug 01, 2011 | Dryers
Dryer runs, rotates, and air blows but does not blow hot air, therefore cloths will not dry.
heatman101
Apr 13, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
Dryer blows cold air, drum rotates, light inside does not light up & it is not heating up
remove the back and check the low side limit switch on the heating element housing! as well as look for lose contacts on the limit switches which are a good indication there bad
Jan 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer working but only blows warm so takes ages to dry washing
if its blowing hot air only and not turning the drum, sounds like the belt...
Oct 08, 2009 | Dryers
Top rear vents blow out cold air[ 2005 cadillac srx ]
Hello according the the manual, the back vent are to blew cold air only..the fronts vents are suppose to the entire car...
Feb 01, 2009 | 2005 Cadillac SRX
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
