Question about Icom Ic-m34 Vhf Waterproof Marine Two-way Radio
Radio not receiving on any channel
The radio can transmit just fine, everything seems to work great, just does not receive any transmission on any channel. The speaker works just fine. I can get sound when sql is 0 or when I activate the Aquaquake feature. I also opened the unit and tested 8 ohms across the speaker. visual inspection of circuits did not reveal anything unusual. I'm hoping an expert can give me another troubleshooting tip as I dont think sending this in for repair is going to be worth the cost.
  • Icom Master
  • 3,287 Answers
Hi Mike,
The manual for this radio (in Adobe .pdf format) is available for download directly from Icom America, free of charges.
Since the "AquaQuake" function works and you do hear static when the squelch is off, that is sufficient to let us know that the voice coil of the speaker is functional and should produce sounds with the right signal applied.
The first thing to determine is if you're close enough to another operating transmitter for the radio to receive a signal. One of the 10 weather channels the radio is capable of tuning should be close enough produce some intelligible audio from the speaker - assuming the squelch setting isn't set too high.
If a WX channel works, then you'll need to see if there's a VHF Marine band transmitter operating nearby. You might need to set another Marine band radio receiver up to verify that there is indeed a signal present on the particular Marine band channel that you're monitoring. A list of frequencies is published on pg 27 (of the manual linked above) in case you need to convert between channel and frequency to tune on a non-channelized radio.
Outside of that, there's little the end user can do without specialized test equipment, schematics and of course, training. Many shops will be happy to provide an estimate for repair when provided with a small bench diagnostic fee. This fee is usually applied towards an authorized repair by most reputable repair shops.
I hope this helps & good luck!
Posted on Nov 27, 2012
Testimonial: "Thanks for providing the additional troubleshooting tips and the link to the manual. "
  • mikedbom
    mikedbom Nov 28, 2012
    Thanks for the reply. I have tried using a friends radio with no luck. I have also tried to get a weather channel working without luck. I understand this may be out of my hands now so I will pursue a repair if its not too much. Thank you.
  • Steve Nov 29, 2012
    Good luck Mike. Try Icom for either their repair or a list of authorized repair shops if unsure about any local shop. Their site:http://www.icomamerica.com/en/support/de...
Stuck on rx mode
Rx is an abbreviation for receive. (Tx is transmit) There are a variety of reasons a radio will be "stuck" in Rx:
1) Another radio in the group is stuck in transmit and you cannot reply if your radio is receiving the other radios transmission.
2) Your radio is programmed for Rx only.
3) Your radio has a Tx problem such as a bad mic, or something covering the mic opening.
4) Your battery is low or bad. It takes more energy to Tx than to Rx.
Best regards.
Feb 07, 2014 | Cobra LI3900-2DXVP (14 Channels) 2-Way...
Receives fine transmission is very poor
Transmit issues can be related to a bad or poorly charged battery. It takes more energy to transmit than to receive. Try swapping batteries with a known good radio to see if it solves the problem. Clean your battery contacts with a pencil eraser and if needed replace the battery pack.
Best regards.
Nov 24, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
I can't get either radio to transmit or receive
try this get someone with a radio or scanner and see if you can be heard on there radioor try this put the radio in simplex mod and turn off the tone
Jun 26, 2009 | Motorola T5920 (7 Channels) 2-Way Radio
Transmitting
its the coax. i had this same issue. i thought a bought a great strand but, it was very poor in design and it developed many breaks over time, reducing its transmitting ability. I would also check the mic wire and head connections as well. this is a problem spot at times.
Feb 25, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Audiovox FR530
follow instructions on page 13 of your manual "using monitor button" place receiving radio in monitor and key up other radio. It is better if you have someone help. have another person take the radio to another room away from you to complete test. sometimes if the radios are two close too each other they will cancel each other out.
Aug 18, 2008 | Audiovox FR530 (14 Channels) 2-Way Radio
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Icom Ic-m34 Vhf Waterproof Marine Two-way Radio Logo
354 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
