Question about Oster HDX23 12-Cup Coffee Maker
My coffee maker wont brew
There is power running to the coffee maker however when i press the brew button it does nothing :(
    New Friend:
I cant clean it cause it doesnt pump
Posted on Jan 01, 2017
2 Suggested Answers
SOURCE: I've lost my manual for the Oster coffee maker
Pot needs cleaning. Fill reservoir with 4 cups of vinegar. Press the SELECT button until the red CLEAN indicator light turns on. Let it perk through. It will take 45-60 minutes. It brews a few cups, stops and then should brew the remainder of the vinegar. When the cycle is complete the light will burn off and the coffeemaker will turn off. Discard vinegar solution and run a couple of pots of clear water through. Hope this helps.
Posted on Mar 26, 2010
Why did our keurig b70 just quit working?
Try unplugging it for 30 sec. and plug back in. Give it time to reset. Hope this helps
Feb 05, 2018 | Keurig Platinum B70 Coffee Maker
Mr coffee keurig problems
You have to select a serving size before pressing the brew now button.
Jan 06, 2014 | Coffee Makers & Espresso Machines
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Pressed the brewing button and machine says brewing but nothing come out
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 28, 2011 | Keurig Platinum B70 Coffee Maker
Coffee doesn't brew
when setting up one has to run a tank of water through you, first you had button for power, then you have two blue buttons for water through the system ater, unfortunately after blue buttons nothing happens, could maybe the tank should be hot water?
Jan 20, 2011 | Keurig B60 Coffee Maker
It says it's brewing - - But It is Not???
If it won't pump water through, how are you going to run a descale? Also this model is supposed to tell you if scaling is an issue. We called Keurig, they said, we will send you a new one.
Mar 21, 2010 | Keurig Platinum B70 Coffee Maker
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart grind and brew's program light wont stop blinking
Could be electrical, but: Hold in the program set button for several seconds. Set it for some time. Press the program set button one more time. See if it resolves the issue.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart DGB-500 Coffee Maker
Oster HDX23 12-Cup Coffee Maker Logo
179 people viewed this question
Top Oster Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Think Crucial
Think Crucial
ray gallant
Are you an Oster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
