Ineed to know power supply voltage to imaginair by aero air mattress MX-B0
The cord with power supply to airpump needs replacment
  • 3,799 Answers
Try asking in a more relevant section. But you might try looking on your old psu.
Posted on Nov 28, 2012
The air mattress was working fine the night before and then last night did not want to inflate. The motor does not start, it is plugged in, the socket works. I plug it in and go to turn the know to inflate...
most likely if you pump is not working, the intake must be clogged preventing air from passing and cooling the pump. That's how pumps and things like hair dryer short out. Or something could be blocking the fan from starting.even the power cord could be bad, I would check those things and go from their.
Jul 08, 2014 | Swiss Gear SwissGear Queen Raised Double...
Need a replacement valve cap for an Embark Queen air mattress
I went to dirt cheap yesterday and purchased a Embark Air Mattress and once I got it home I discovered that the mattress didn't have a valve cap. I want to know if you could replace the cap without any cost? If you would like to send me one here is my address P.O. Box 282 Blue Mountain Miss 38610 Thanks for your help
Feb 16, 2014 | Embark Queen Pillow Top Double High Air...
WHERE TO FIND A AC POWER SUPPLY
Any electronics supply store should have what you need. Try searching online. RADIO SHACK should have this power supply.
Dec 14, 2013 | Radio Shack Radio Communications
In asus P5GL-MX mother board the power supply regulator ic 2 piece has been damaged (short) how would i know plz help me
Hi if the regulator ic has been damaged in your power supply even you replace that there are some electronic component where also damage because the ic will not damage where there is no over voltage flow on it. This means there are some resistor or a transistor is also shorted it advisable to replace a new one than to repair your power supply. Because even you repaired it the performance and the life span of your power supply is not stable. So it better to replace a new one.
Jul 14, 2011 | ASUS P5GL-MX Motherboard
The power supply for my Linksys router was damaged. The cord was damaged and I am replacing the plug inserts into the router. Ine side of the cord has a gray stripe. Is this the negative connection?
In electricity ussually the cord with a different color stripe is positive, and plain black is negative or ground, I recommend you check out another power supply or go to linksys official website to get a new one. Hope you solve your problem soon.
Mar 30, 2011 | Computers & Internet
Ineed power cord for ge electric griddle model 106733 number on power cord is mptc-1a
Hi .. you can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes.
Apr 07, 2010 | Presto 07034 Electric Skillet
Error e803 checked power supply next to ac cord
Well most likely its a low voltage problem, check power outlet (110/220) or you need to replace the low voltage power supply board. Before replacing the power supply board you must check that the voltage is 24V by using a volt meter.
Jan 22, 2010 | Canon Office Equipment & Supplies
Ineed the voltage and connector polarity for the ADS TV ELite Pro
I just found one too, same situation... no power supply. Mine has box and all. On the back of the box, it reads:
Power Supply 7.5 VDC power adapter
It doesn't say what polarity, but judging from the board... I'm gonna' say + in the center. That's what I'm gonna do.
May 31, 2009 | A D S TV Elite Pro/w Remote (TEP-100R)
Voltage of LaCie power supply
if you remove the old one it should be labelled on the side of what its voltage is and just get the same as that one
May 10, 2009 | Computers & Internet
Gigabyte K8NS + shutdown problem
Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS Test it first by Shorting the connections in the motherboard. Use a Flat head metal screw driver. Be carefull though. A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver.
Sep 21, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
