Question about Cell Phones
I have a net 10 t401g samsung phone and I locked it and now it says puk pin I don't know what to do someone help plzz
Unlock code t401g
Dear Brother:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 11, 2012 | Samsung T401G Cell Phone
Doesn't show contact of sim card of samsung galaxy GT-s5570 can u give me format code of samsung GT-s5570
I'm Ben and -- hopefully -- I can provide some meaningful
assistance.
It seems that your SIM card is locked.
SIM CARD:
If you enter a wrong PIN code too many times, usually three,
your SIM will lock itself. This protects you from someone using
your personal information or making calls if your cell phone is
lost or stolen. You may see "PIN blocked" or Enter PUK code" on
your cell phone display. The PUK code stands for PIN Unblocking
Key. In the U.S., the PUK code is rarely provided when you get
your subscription.
If you do not have your PUK code, contact the Customer Care
customer again. Give them your phone number and once they
are sure it is really you, they will give you the PUK code.
You will then be asked to set a new PIN code. Once you have
your PUK be sure to keep it in a safe place.
Note that if you enter a wrong PUK 10 times in a row, the SIM
will be permanently blocked, and you'll need to purchase a new
SIM card.
Jun 17, 2012 | Samsung Galaxy GT-S5570
I need my PUK Code.
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
Oct 15, 2011 | Samsung T401G Cell Phone
Hi, I'm having trouble getting my phone unlocked. I punched in the wrong numbers 3 times, and then it says I have to unlock my PUK lock, which i don't even know what it is. So... how can i unlock...
Hi!
When you purchase a sim card usually gives you 2 codes, first one is PIN CODE and the other one is the PUK CODE. Puk code is the super-long combination of numbers written on your sim package, it should be near the phone number or the pin code. If you don't have the sim package to recover your Puk, then you should contact the customer service of your mobile network.
I hope this will help you! Have a nice day!
Sep 02, 2011 | Samsung Cell Phones
I forgot my password to my samsung intercept and now all I want to do is reset the phone, but I don't know how
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave'.for today.
As you evaluate my advise and suggestions, there are a few things you must keep in mind:
• I did not diagnose your problem and am therefore only able to evaluate what you tell me. For example, if you ask me a fuse location, that doesn't mean that I can tell you the reason why the fuse blew.
• A thorough diagnostic approach involves the use of technical equipment, such as voltage meters. scanning equipment and other sophisticated devices.
• Lastly, fixing one problem can very easily reveal a problem with something that you might consider unrelated. If that happens, you might want to view me as being incompetent.
Subject: How to unlock a cell phone and/or SIM card
Customer's exact description: I forgot my password to my samsung intercept and now all I want to do is reset the phone, but I don't know how
Discussion: Problems of this type can be either Locked SIM card Locked, or Lost Password. Customer did not provide sufficient detail to narrow the problem.
Solution: Provide instructions on how to deal with the two possibilities.
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
You can also do it without any assistance from anyone, However, be sure to read the following carefully because there are pitfalls.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
Aug 16, 2011 | Samsung Cell Phones
I set a pin code on my Samsung Galaxy S so that my cousin couldn't get into it while I was away, and I've forgotten the pin code! Nothing comes up about logging in with my google mail account and i...
It seems you troubling yourself my friend :D, don't worry try your puk code to unlock samsung galaxy s pin code. PUK code can you get from your sim card bundle or calling your network provider, the idea is to enter any password until your phone asking about puk code then you can use that to unlock samsung pin code and reset it to default. Good luck!
Aug 02, 2011 | Samsung Galaxy S GTI9000 Smartphone
HOW DO I FIND MY PUK CODE ON MY SAMSUNG T401G? I ACCIDENTLY PUT A PIN LOCK OR SOMETHING ON IT. THANKS.
PUK CODE is provided by the SERVICE PRIVIDER.
Call your service provider from another mobile or land line phone.
Jun 01, 2011 | Cell Phones
I have a Straight talk Samsung T401G phone and its asking about a PUK number what the **** is that?
It means that you (or somebody) has tried to guess the PIN code for your SIM and got it wrong 3 times.
You now need to enter the PUK (or Personal Unblocking Key) to access the SIM card and use the phone.
If you dont know your PUK, you can get it from your network/service provide/carrier (for free)
Do not try and guess the PUK.
If you enter PUK incorrectly 10 times, the your SIM card will become permanently blocked, and you will need to buy a new one.
Sep 18, 2010 | Cell Phones
I dont know the puk code for my Samsung SGH-T401G....can u help please!!!
The PUK code for your Samsung Unit is being asked because you have typed the PIN for your SIM card incorrectly. Only your service provider can provide you with the PUK code. If you try to put in wrong code 10 times, that would "fry" your SIM card and you will have to purchase a new one. The best solution to your problem is call your provider and get that correct PUK code from them.
Sep 12, 2010 | Cell Phones
My pin is blocked and its asking me to enter PUK. i have a net 10 t401g phone
My dear:
Aug 14, 2010 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
