Question about Toys
The middle of my pack n play won't stay down
I cannot get the middle and legs of my pack n play to stay down on the floor when I set it up. It seems like they won't lock into place when I push the center down, whether or not the sides are locked.
3 Suggested Answers
  • 6 Answers
SOURCE: how do i get the sides to lock/ stay up on my
I think the problem is the way that the safety feature prevents the locking mechanism from moving while the bottom is flat Be sure that the bottom is raised about half way and the rails should lock (or unlock) for you. Hope that helps. wdeblancjr@aolcom
Posted on Jun 14, 2009
  • 125 Answers
SOURCE: Problems re opening the Graco Pack N Play - one side won't lock
if so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
Pls let me know if I helped
Posted on Oct 06, 2009
Hard to push
There may be a dial or something to set your unit to "floor" or low, and "High", all for the type of carpet or flooring you are vacuuming... change the setting to the middle or "floor"/ low.
On the other hand, here is a silly experience we may be sharing- sometime these units have wheels set so that, when the unit is "parked" or upright, wheels come down in the back, thus pushing the front down. You can turn it on, but the wheels won't go back into the unit until you move the handle from the upright position... My ex spent 15 minutes trying to get the vacuum to be normal- and all she had to do was just get the handle back at 2 or 4 o'clock position, and it worked fine...
if that's what you did- you aren't the only one! :-)
Good luck.
May 26, 2012 | Dyson DC33 Multi-Floor Upright Bagless...
Lost one of two bolts on Combi USA pack n play model 9400 -- the corner with the light and music -- and it won't stay together. Can't find replacement at any hardware store. Help!
Call Combi and explain that the bolt has fallen out and is missing. I am sure they will send you one. Customer service will work for you if you are nice and if all else fails maybe they will sell it to you. Couldn't cost much.
Toll Free: (800) 992-6624
Feb 11, 2012 | Graco 9445DOH Crib
Can you send me the directions for setting up the cosco playpen
Try this step by step instructions Hope it help you
Instructions
1. Unfasten the floorboard from the folded play yard frame by loosening the hook and loop tabs holding it in place.
2. Unfold the play yard and set it upright with its four legs on the floor. Pull out on opposite corners to spread the legs of the frame.
3. Pull up on the plastic handle in the center of the floor of the play yard to unlock it fully.
4. Pull up firmly on the center of each of the four side rails until they click into place, while continuing to pull up on the center handle.
5. Push the center lock down until it clicks all of the legs into place.
6. Place the padded floorboard into the play yard.
7. Locate the two hook and loop tabs located on the underside of the floorboard and pull them through the slots in the bottom of the play yard frame. Secure the tabs underneath the play yard.
Jul 02, 2011 | Cosco Juvenile Cosco Funsport Playard
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
I have a Maytag Model # LA806-02, which dances across the flor when in the spin mode. Tighting the three centering spring has helped very little.
If your Maytag is dancing across the floor the most common problem is the leveling. If one or more of the feet are not level it ill wobble and walk around the floor. When you level the machine on the top both directions make sure the set nut is tightened so you will not have to retighten it again later.
May 08, 2011 | Maytag Washing Machines
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
Don't have manual for fisher price ocean wonders deluxe playyard? How do you keep the sides up?
All pack and play play yards require the bottom floor to lifted like a little volcano in the middle before the side will go up or down. Some have a twist lock others just pull upward. Lift the middle handle up about 6" to 12" and then raise the sides. Once all the sides are up, press the floor flat. Done. Nothing goes up or down until the middle safety is up like a volcano.
Apr 25, 2010 | Fisher Price Deluxe Perfect Support Baby...
Washer must be out of balance
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Jan 08, 2009 | Admiral AW22 Top Load Washer
Pakc & play set up
I had the same problem with the pack & play that I used for my youngest. It turns out that the centerpiece (looks like an extra leg for support of the pad) needed to be pushed all way down, where the leg was resting firmly on the ground, before you lock the sides. When it was time to fold the pack & play back up, you have to pull the middle up first for it to unlock properly.
I hope this helped!
Jan 13, 2008 | Graco Quattro Tour Kentshire Stroller
Toys Logo
85 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
