Question about Jenn-Air JER8885RAS Electric Range
When turning the oven on an error message appears. Option not available
Turning the power off and on sometimes resets the oven. I have replaced the control, the oven worked for about 5 days. I replaced the control a second time and the oven worked for 8 days, then error message appeared again.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
Check all the wire connections to be sure they are seated and tight.
Posted on Nov 27, 2012
5 Suggested Answers
SOURCE: oven will not work
Any codes? Most like the temperature sensor probe. I had to replace it after the self cleaning cycle. It had an F3 code.
Posted on Mar 18, 2007
bestdarngood
  • 3037 Answers
SOURCE: F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Posted on Mar 22, 2008
docjohn174
  • 943 Answers
SOURCE: Problem with the oven - control panel?
hi .thanks for the question. i would check the cord going ito the stove plug .pull it out and look for a discoloring of the brass prongs. also look for loose connection in the stove where the cord attaches to the stove .that could be the problem .thanks the appliance doc rate me please
Posted on Oct 01, 2008
mnwarfield10
  • 452 Answers
SOURCE: Set oven in clean mode....a
make sure you time is set also make sure you set it back to manual ...normally it has a picture of a hand . 07779933829 uk
Posted on Feb 23, 2011
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
When the camera is switched on the lens goes in and out twice and then the message that appears on the screen is 'turn the power off and on again'
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
May 09, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
The lens will not retract or close, when hooked up to usb connect camera just turns off, when turning camera on error message to camera on and off again is shown. I have gone in and reset/initialized it,...
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Dec 20, 2010 | Sony Cybershot DSCW370 Digital Camera
It put access than after it starts beeping and appears turn the power off and on again
Turn on the camera.
Dec 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
When powering up my cyber-shot N50, the lens extends and retracts several times, then a message appears, "Turn the power off and on again" I can download to laptop, took battery out, charged up and put...
The exact steps can be provided with the correct model #. The model # starts with "D". Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cyber-Shot DSC-F55 Digital Camera
Error message when turned on
Turn on the camera.
Apr 27, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
How do I solve a system error E000
You have to get into service mode and reset it under Funcation. You may have a power problem with your outlet. It could also be a problem with the fixing unit..
May 23, 2008 | Canon imageRUNNER 1023N Black and White...
Jenn-Air JER8885RAS Electric Range Logo
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
