Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50 Logo
Posted on Nov 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i use a 3 way switch if I don't have but one switch in the room
Anonymous
Level 3:
  • Master 843 Answers
  • Posted on Nov 30, 2012
Anonymous
Master
Level 3:
Answers
843
Questions
0
Helped
394474
Points
2420
Yes, but one of the outputs (runners) will remain unused. If your switch has pigtail wires (rather than screw terminals) the unused one will be live when the switch is off. Be sure to put a wire nut on the spare wire to insulate the end of it.
Is there a battery replacement for my L4 that will give me a longer running time?
There isn't room onboad for bigger batteries. But you can cheat by constructing a two wheeled trailer just big enough to hold two more batteries they can be as big as you want. When the on-board batteries get low flip a switch and your running on out-board batteries. Be sure the trailor is conntructed to be as lite weight as possible. you can buy trailers for scooter. I did it the lazy way, I wired my external batteries directly to my internal battery terminals due to amp loading.If they are lets say 50amp to your 15amp on- board batteries you are going to go way more miles than with15amp batteries. WARNING this setup you don't hook fully charged big batteries into discharged small. batteries. I don't let my on-board batteries get to discharged. I've spliced into the main battery terminal lines..so that they are thick enough to handle the amp load which are 12 gage. I also have a 50 amp connector between the external scooter and the trailer for quick disconnect
2004 Pontiac Montana, when I open my drivers door the radio doesn't always shut off any more, I opened the passenger door & it shuts off, I think it's a door pin switch but I don't see a...
You don't find much with the door jamb switches any longer. Its all done inside the door with the switches being on the door latch.
the radio should still be able to be turned off manualy ;)
1helpful
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Added a 322 reciever to my lake house to be able to watch tv in 3rd room i had 2 standard recievers before. i installed a dish pro quad lnb & reciever had a separator w/it says dp plus 123254 tuner 2...
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
1helpful
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
My Whafedale WH-AV4337 remote switches the unit on and off but will no longer feed the TV sound to my speakers. The AV (Digi) flashes "unlock". I don't have a user's manual. Any...
Hmm, I don't know why the emphasis is in the remote here.
Front panel switches still exist on most products so ramble across the room and try touching it with your finger so we don't have to factor in a possible remote malfunction.
I can't locate a free manual anywhere but YOU should contact Wharfedale and ask them where you could get one because the website only lists a handful of speaker downloads.
http://www.wharfedale.co.uk/Home/tabid/37/Default.aspx
However the digital audio for the "AV" is arriving, it is probably not syncing up or the signal / cable is failing or disconnected. Try swapping with known good cables or input jacks.
I need the steps to take out my 1981 Ford F100 alternator.
Why would you need that?
You should have some room to work,
and only 2 or 3 bolts to loosen & remove.
We don't have that, nor does a factory
service manual
I HAVE A OVER HEATING PROBLEM
Assuming you're talking about your amp is overheating, it usually means that you don't have enough room for your ventilation. You can keep it where it is, and wire a couple of computer fans from Radio Shack.You should wire them up so that they turn on with a switch. Another problem is the amp is basically out in the open, speakers could be wired incorrectly. If your amp is stable down to 4 Ohms, and you have them wired down to 2 Ohms your amp can run hot. The way to check this is to hook up a multimeter and see what Ohm load your amp is "seeing." If you don't have access to one, then just simply go to a local audio store and ask them to check that for you.
1helpful
3answers
I have a Dukane MCS350 intercom system, everything works on the system when bottons are pushed, however there is no sound from any speakers... when you call a room, it states the room number with a...
A room number preceded by a 'P' indicates the room is in privacy mode. This could be the room switch is in privacy mode, or there is a wiring issue. In this mode, the room can hear calls/pages, but you cannot hear the room from the console.
If the room cannot hear pages/calls, then you have a wiring problem.
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
