Question about Speed Queen AWS52NW Top Load Washer
My speed queen spins very slow with a full load. But if I only put a few things in it works?
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then okay
Posted on Jan 24, 2013
tzweeb
  • 318 Answers
SOURCE: speed queen wont spin or rinse
i would guess you have something blocking the pump. take off the hoses on the pump and see if there is a sock or something in the hose.
be aware that when you take the hoses off there will be water trying to get out, so have a bucket and towels ready. it is best if you can pinch off the hose first, but not everyone has a way to pinch the hose.
Posted on Jan 08, 2009
  • 20 Answers
SOURCE: washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
Posted on May 23, 2009
  • 254 Answers
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Posted on Feb 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: 10 year old Speed Queen washer, spin cycle does
likely the lid switch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
rickyrt441
  • 4399 Answers
SOURCE: TOP LOADING SPEED QUEEN HAS
Thanks for choosing FixYa and welcome. It sounds like your timer switch is not working to me. As you probably already know, this is what allows it to go to the next setting. The switch may be bad or it is possible that it is not getting power due to a loose connection or bad wire. Your control board may not be picking up the signal. It could be either one. I would suggest the timer switch first though. You probably need a new one.
Posted on May 23, 2011
SPEED QUEEB AWS17NW HOW DO I INCREASE SPIN SPEED IT SPINS WAY TO SLOW CLOTHES ARE STILL WET
Well could have a bad motor, and depends how much are you loading into it. Remember the more cloths you put in it and all that water collects in the cloths and weighs it down. Try a Smaller load! Unless this waster is a HE Washer it wont.
Sep 28, 2014 | Speed Queen AWS17NW Top Load Washer
I have a 2 month old Speed Queen top load (542) after the spin cycle, the clothes are still very wet
i assume the majority of the water is being pumped from the machine? if the clothes are very wet check your "fabric Select" setting and ensure you are not wahing on delecate handwash or wool wash (knits) setting, in this setting there will be a very slow or no, spin so the clothes will not stretch and have to be laid out to dry this is normal. if you are on a Permpress or regular setting the spin should be faster, also check your cycle selection is for Regular or permpress and spin is not missed .
I hope this was useful
Feb 15, 2013 | Speed Queen AWS52NW Top Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
Washer spins but really really slow, not fast enough to extract water
it can be the pump if it does not get the water out fast it will slow spin best way to check put it on spin with nothing in and watch it if it does the same then the moter is faulty change it try ebay for replacements
Jul 28, 2009 | Speed Queen ATS90AWN Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Kelvinator or (Speed Queen Top Load washing machine)
You probably have the wrong belt, and its to small? Go to repairclinic.com or google Kelvinator parts. Order the correct belt.
Apr 15, 2008 | Speed Queen AWS52NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
51 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Charles T Nevin
Charles T Nevin
fta777
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
