Question about Jenn-Air JED8430 Electric Cooktop
How do you level the stove top
Just m oved into home with ceramic stove top. Not level. Front end is low.
The bottom front of the range has two little legs with hex bottoms. Lift or tilt back the range until you're able to slide a shim (I used a metal ruler) under one of the little legs. Then, unscrew the other leg until it meets the ground. Remove the shim and unscrew the remaining leg until it meets the ground. Check for level and repeat until you get it right. I just did this just 5 minutes ago and if I can do it anyone can.
Posted on Jan 28, 2011
Change ceramic igniter on gas stove oven
Most ovens are servicable from the front by removing the shelves and lifting out the bottom. The lower cover may also be removable.
Dec 12, 2013 | American Range ARR-486GR-LP-DK Color 48"...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
Maytag schott ceran front eye wont get hot
I navigated the SCHOTT website to find a solution and was able to find out how to properly clean my SCHOTT stove top. I would check the Ceran FAQ list to see if your question is answered before anything else.
Nov 19, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Gas ignitor keeps trying to ignite after stove is off.
Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
Sep 13, 2010 | GE Cooktops
What does F3 mean on a GE self cleaning ove. When
Your oven tempertaure senser is bad (RTD)
Jun 25, 2009 | Cooktops
Puiter stain on stove top
ITS NORMAL FOR GLASS CERAMIC, NO KIND OF CHEMICAL TO CLEAN.
TNX GERBEE
May 26, 2009 | Jenn-Air JED8230 Electric Cooktop
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Ceramic glass stove is cracked
HI
You should be able to replace the top only.
Normally if this is your fault, it is not covered by warranty. Normally this would be if you dropped something onto it. This would leave like a star shap series of cracks.
If its down to manufacture, this should be covered under warranty. This damage normally looks like just one long crack, no impact mark.
Check with the manufacturer
Rob
Feb 18, 2009 | Cooktops
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
1,045 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
