Broken door clip on maytag atlantis
One of the plastic clips that holds the tub door in place on my Maytag Atlantis MAV6600-AAW top loading washing machine broke. Can I replace this?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Are you talking about the "lid hinge"? Here is the part to order.
Posted on Nov 27, 2012
  • 1 more comment
  • pinkgram
    pinkgram Nov 27, 2012
    Yes, I meant the lid hinge. Thanks for identifying the proper term for me. It is exactly what I need! I appreciate your help so much.....thank you!
  • pinkgram
    In addition to the hinge piece there is a small plastic washer/spacer (?) that fits on the end of the hinge between the lid and the body of washing machine. I don't see this in the parts diagram.
  • Richard Roth
    Richard Roth Nov 27, 2012
    You need the hinge bushing also. Here is that part.http://bit.ly/WX5Imt
Jimster
  • 240 Answers
SOURCE: Removing Tub from Maytag Atlantis Washer
I do believe that when you remove the four bolts, it should come out. Sometimes you have to use a little force and shimmy left to right to get it to break loose (no hammers please) especially if you have a lot of scum build-up from soap. They can really be a bear sometimes to remove. Maybe put your foot in the bottom of the tub and hit it on both sides to work it free. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 90 Answers
SOURCE: maytag atlantis leaking in the tub
replace water valve
Posted on Jan 06, 2008
vest6
  • 196 Answers
SOURCE: My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Posted on Jan 15, 2008
ginko
  • 19396 Answers
SOURCE: Door Clip Assembly
which is the model?
Posted on Mar 08, 2008
futureloginn
  • 734 Answers
SOURCE: Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Maytag Atlantis leaking water, not from hoses - solution?
Hi this could be coming from a number of places. First get putty knife or possible a butter knife and pop the top. There are 2 clips holding it on they are at the top front about 2" in from the corners... Push in knife and pull up on top at the same time...Fold the top back out of the way and observe inside to see where the water is leaking. If it is coming from underneath you may need to remove the front to screw top left and right then fold out and up to remove. Observe underneath to see where the leak is.
If I can help with anything else please let me know.
Apr 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
How do I get the aggitator out of our Maytag Atlantis - it has a steel tub
most of the maytag agitators simply need to be lifted firmly upward and they'll snap off. Watch your face!
Dec 09, 2009 | Maytag Atlantis MAV8551 Top Load Washer
How do you open the front
OPEN TOP, 2 CLIPS RELEASED WITH PUTTY KNIFE, ONE ON EACH SIDE OF FRONT ABOUT 2"-3" IN FROM SIDE. CLIPS ARE ABOUT 3/4" WIDE. ONCE TOP IS OPEN, LEAN IT BACK IT WILL REST ON PLASTIC BRACKETS, YOU WILL FIND 2 HEX HEAD SHEET METAL SCREWS THAT HOLD THE FRONT TO THE SIDES. REMOVE THESE SCREWS AND TILT TOP OF FRONT PANEL OUTWARD. THERE ARE 2 LOWER BRACKETS THAT CONTINUE TO HOLD THE PANEL. THE PANEL CAN BE LIFTED OFF THESE ONCE THE PANEL HAS BEEN TILTED OUTWARD.
Nov 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Aug 31, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
