Question about Lexmark Wheelwriter 5 Series II Typewriter
Printhead won't go left of center
Releasing the margin release will only move the prinhead to the center of the machine. I can't figure out anyway to move the printhead to the left side of the machine
  • 610 Answers
Check the 2 silver rails that the carriage rides on, they need to have a little bit of oil on them. I f they are dry to the touch, they need to be lubricated with a little bit of a light weight oil. This could also be caused by bad keyboard. Do all the keys seem to work? Try turning machine off and move carriage by hand to the left then turn on and see what happens.
Posted on Nov 28, 2012
2 Suggested Answers
  • 3594 Answers
SOURCE: Need to release left margin, it's stuck in the
Turn the machine off move the carrier back & forth by hand and see if it will go all the way to both ends. If it doesn't look for debris in it's path. If it moves put some WD40 on the silver shaft that the carrier slides on. Put some WD40 on the bfront and rear carrier motot bearings, the front one can be reached from inside the T/W the rear one will require snaking the straw thru the case.
DickyO
Posted on Sep 29, 2011
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
Need to release left margin, it's stuck in the middle and won't allow me to move the margin any farther to the left.
DickyO
Sep 29, 2011 | Lexmark Wheelwriter 15 Series II...
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Cannot margin release ]3] to extend into hot aone
HOLD DOWN THE "ALT" KEY THEN HIT THE 3 KEY THEN USE THE BACK SPACE OR SPACEBAR TO REPOSITION THE PRINTHEAD. THIS WILL ALLOW YOU TO MOVE PAST THE MARGIN ONE TIME. IF YOU WANT THE MARGIN SET IN A DIFFERENT POSITION - MOVE THE PRINTHEAD TO WHERE YOU WANT THE MARGIN SET, HOLD DOWN THE ALT KEY AND PUSH THE 4(L MAR) OR 5 (R MAR)
Dec 19, 2008 | Brother SX-4000 Typewriter
HOw do i release the margins on this typewriter?
It can be a little confusing on this machine. To reset the left margin, (at a position to the left of the margin), go to the left margin, hold down the ALT key, then push the key under where MAR REL is printed at the top of the keyboard. Then, using the BACKSPACE key, move the printhead to the position where you want the left margin set. Then hold down the ALT key and hit the key under L MAR. The left mar. should now be set at that location. To set the left mar. to the right of where it is, just move the printhead to where you want it and hold down the ALT key, and hit the key under L MAR. The right mar. set works the same way.
Oct 22, 2008 | Brother SX-4000 Typewriter
Cannot move the right margin out.
Hit the margin release, morve the printhead to where you want the margin set and hit R MAR. This should reset the margin. You should also check to be sure there is no forien object in the machine preventing the printhead from moving to the right.
Oct 20, 2008 | Olympia Supertype 330 Typewriter
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
Carriage return problem
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Lexmark Wheelwriter 5 Series II Typewriter Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
