I have an old Lady Kenmore washing machine that for the past couple of months now will not dispense water into the drum for a washing cycle. I have to manually fill up the tub with water and when the
Lady Kenmore, last four of the model number is 6921 as the others are not legible anymore.
  • photogmomx3
    photogmomx3 Nov 27, 2012
    ...it cut off the rest of my response but here's the rest: ...appropriate height is reached in the tub, the cycle will start washing. There is a buzzing sound that comes on when I first engage the washer to start filling up with water and sometimes out of nowhere it will begin dispensing water, but only for a couple of minutes. The rinse cycle has the same results to where I have to manually add water to the tub in order for it to start that part of the cycle. Any ideas as to what could be causing this?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You will need to replace the "water inlet valve". Se if you can get a part number off the valve. I will need that number or the complete model number to point you to the correct part.
Posted on Nov 27, 2012
  • 1 more comment
  • photogmomx3
    One has the part number 64163 and the other has the number 64164 on it. I would assume I'd have to replace both considering neither the hot or the cold is working at the moment.
  • Richard Roth
    Richard Roth Nov 27, 2012
    Here is the valve that comes up for that part number but I don't think it is correct. Take a look at it.http://bit.ly/WXc7yj
  • photogmomx3
    Yeah, it's the substitution that Sears is showing as well.
2 Suggested Answers
  • 209 Answers
SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Posted on Oct 14, 2007
Managemylife com sears
Either the cylenoid to let the water in is bad.
Or the hose from the dispenser to the drum is clogged.
Most common with powder detergents.
Some really hot water poured into the dispenser may
solve the problem.
Aug 21, 2014 | Kenmore Elite 45986 Front Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Strange smell coming out of Maytag Neptune MAH8700AWW
This is joyce
I am assuming that the smell is mold that is what happens in these units, the door gets closed and they capture the moisture inside and it molds around the door and in the dispenser, you have to run about 1 cup of bleach a month in them to keep them clean and in the dispenser you have to spray them with pure bleach with a spray bottle and take tooth brush and scrub the top to remove mold or it will take over. make sure their are no clothes in waher whenn you run this cycle.
this should solve this problem,
please let me know if this works, it did on mine
thanks
joyce
Feb 07, 2009 | Maytag MAH8700A Front Load Washer
Kenmore Series 70 has musty smell and sounds like water inside
The water will always be in there. It is in between the basket and the drum. That is normal. However if you want to get rid of the musty smell there is a good tip that I have. You can find this on my profile too. Just take about a cup of white vinegar and put it in the drum and wash on hot heavy load. This will clean the tub and all hoses as well. You can do this every few months or even every month if you do a lot of laundry. Put some vinegar into the bleach dispenser too and the fabric softener area as well. This way you will clean everything. It is much cheaper then going out and buying that expensive cleaner made for washing machines. Let me know if you have any other questions and if this was helpful. Good luck and have a great weekend.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
I have a Kenmore top loading washing machine that is 7-8 years old. (model # 110.92575110). It has a fabric softener dispenser that sits on top the agitator. It has stopped dispensing properly. Most of the...
pull the dispenser of turn it up side down now move green clip around dispenser down..take a little screw driver and remove all that wax build up...turn dispeser right side up and let hot water hot as possiable..now you should be find...if not add a little bleach with the hot water rinse out..if your getting fabric softner around tub ring ,,its to thick,,instead of dripping down its flying up...fill dispenser to top with water than add fabricsoftner ..it will even it self ,,water first...
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
Detergent not being washed out of dispenser
This suggestion is not too good. If your dispenser opens at the initial stages of the cycle, just a little - pour some water into the dispenser to wash down the detergent. (For my machine i can pull out the dispenser anytime during the wash, except when water comes into the dispenser, but even then i think the water enters the tub.) For this you dont have to hang around the machine for long for it is in the initial stages of the cycle. Later you hv to check the flow of water into the dispenser. Hv no idea how to do it; but i gave you a quick solution.
Mar 01, 2007 | Asko W6021 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
