Question about Kenmore Washing Machines
Wash machine reads f 06
Kenmore elite
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number?Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU.
Posted on Nov 27, 2012
  • 1314 Answers
SOURCE: washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Posted on Jan 20, 2008
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
  • 1028 Answers
SOURCE: Schematics for washing machine
look under console
Posted on Jul 05, 2008
  • 360 Answers
SOURCE: Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Posted on Mar 10, 2009
jimappliance
  • 42 Answers
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Posted on Aug 01, 2009
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
Tip
Jsrock516 - what about motor winding readings from 7.1 to 7.3 ohms? This was...
This advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code. The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
I hope this information is helpful.
on Apr 25, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Calypso Model #110.24086200 SN #CR3808384 is not completing it's cycle and error code (06) shows up. What does code (06) mean?
Error codes start on page 46 and detailed instrustions to run diagnostics start on page 47.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Mar 20, 2011 | Kenmore Washing Machines
Code 06
In the manual for a Kenmore washer the instruction for an F06 code (electrical problem) is :
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer. Re-select cycle and press START.
After that, you might try unplugging then plugging it in again.
Jun 06, 2010 | Kenmore 23822 Top Load Washer
Servise code f 06
"F06" is a Motor Speed error code. The following link explains how to troubleshoot:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and verify all your wiring and connections, first. Sometimes the problem is as simple as a loose plug. Make sure resistance checks are done with the washer unplugged. If you have any questions, please let me know. I hope this helps you.
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
  • Check the MCU
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F and then 06 error/ Kenmore elite HE 3T series 4
well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE 3 displays F 06 code
F 06 cose for faulty motor controller. reomove lower acess panel adn ck for good wire connections (board is in rt front corner) check wiring harness to lower control board,. sometimes a glitch( it is a computer after all). try unplugging unit fro 2 min . if not replace motor control board
Mar 04, 2008 | Kenmore Elite 45986 Front Load Washer
Washer kenmore elite calypso 21086
Jan 20, 2008 | Kenmore Elite 21086
Washing Machines Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
