Question about Lexmark Interpret S405 Wireless All-in-One InkJet Printer
Lexmark Interpret S405 will not print color
Following clearing a paper jam, the printer will not print in color. There doesn't appear to be anything that has fallen into the printer or any jamming. Also checked gray scale and b/w settings and they are not selected- color printing is.
  • Official Brand Answer
  • 3,344 Answers
First, make sure that you're using genuine Lexmark cartridges. If not, replace the color cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Third, perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If the steps above doesn't help and you're using genuine Lexmark cartridges and provided that your printer is still under warranty, please contact our technical support team to have the printhead replaced.
If not, you can go to www.lexmark.com to purchase a printhead.
Posted on Nov 27, 2012
SOURCE: Lexmark X3350 Printer
Thanks for everyones help, what worked for me is to reinstall the software that came with the printer. Works just fine now.
Posted on Apr 23, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark X5470 printer says, "Clear paper jam, then press check mark."
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 28, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
Posted on Jun 01, 2008
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
pineworks
  • 4041 Answers
SOURCE: Lexmark S405 Paper Jam
Hello there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.printertechs.com/tech/mkinst/mk-1300-5fuser1.php
Posted on Feb 10, 2010
Lexmark s450 printhead not moving
Try to check for any obstructions inside the printer. Something could be blocking the paper path and the printhead from moving.
Sep 15, 2012 | Lexmark Interpret S405 - multifunction ...
My interpret s405 printer wont print in color
replace print head. uninstall software and install again. that is all
Jul 22, 2012 | Lexmark Interpret S405 Wireless All-in-One...
I have a s405 interpret stating I have a paper jam. I have went through and cleaned everything and there is no paper jam anywhere that i can see. What do I do next?
There could be something blocking the paper path. Try to get a flashlight and check if there are any foreign objects inside the printer. If you can turn the printer upside down with the scanner cover open, try to do that and shake the printer. If there are foreign objects inside, it should fall off.
If it doesn't help and your printer is still under warranty, contact our technical support team to have your printer replaced. You can find our contact number at www.lexmark.com.
Jul 10, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark s405 won't print in color
You should call on ((+1-800-585-2494 )) Toll Free Lexmark and get help for Lexmark]
Sep 28, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My lexmark interpret S405 is showing the message "paper jam" and this is recurring. I remove the paper turned off the printer then turned on, it again shows the message paper jam when there is no...
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 12, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark S405 won't print or copy in color. Ran utilities, cleaning print heads etc. Only when I physically unplugged it did color show up on the one printer head cleaning page but when I align...
Please visit the Lexmark support page to determine if your printer is affected with the printhead issue. Also, make sure your printer is updated. The firmware update will help give you a highly reliable print system.
Click here to validate your serial number and/or update your firmware.
Sep 03, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
I have got black and grey squares appearing on the paper when i print. I have used the maintenance cleaning section to no avail.
Lexmark recognizes that some of our inkjet all-in-one customers may be experiencing issues with their print quality. We take our customer user experience very seriously, and we strive to ensure that each time a customer prints using a Lexmark device the page is crisp, clear and up to the highest standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Aug 17, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark Interpret S405 is saying : "Unable to authenticate Black,Cyan,Yellow,Magenta" Please help. I have already tried turning off printer and cleaning print head.
Note: Make sure you are using Genuine Lexmark Cartridges.
Aug 10, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark Interpret S405 Wireless All-in-One InkJet Printer Logo
181 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
