Laptop Advent Q200 on start up comes up bright but blank instead of sign in page
BEFORE. Power on. Screen comes up after few seconds saying Advent leading to sign in with password screen. NOW Power on. White or random coloured screen comes up and stays. Sometimes I can get past it by hitting 'return' or on/off button (lightly) couple times. Sometimes just have to re-boot, vicious circle.
  • Computers & ... Master
  • 27,725 Answers
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty.
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly.
Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer
You might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask for a guarantee on the compatibility of the ram before making any purchase
Might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps.
Posted on Nov 27, 2012
5 Suggested Answers
patemi
  • 366 Answers
SOURCE: White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Posted on Dec 30, 2008
  • 7 Answers
SOURCE: Laptop will not start...
2 words: Memory. Motherboard. Check to see if the memory is properly seated by removing the memory cover on the bottom of the laptop. Gently move the two release tabs until the RAM module pops up. Then, gently pull the RAM module out and put it back in, with the gold connectors facing the metal "lip" you just took the module out of. Press down gently on the other end of the module until you feel it click. Replace the cover, and attempt to turn the computer back on.
If this does not work, take the computer in to a service technician or call HP at 1-800-474-6836 and they will do their best to fix the problem.
Posted on May 04, 2009
  • 6 Answers
SOURCE: Laptop Screen goes blank
Are you running on battery or AC? Try using the power cord, remove the battery and see if it continues. I have seen a battery that is on its last legs do some weird things to a computer. Also, check your power management setting. Control panel, power, and set the computer to "always on" just to see if it could be a power management setting. If none of this works, i would back up all your files, and try to reload win xp from scratch.
Posted on Jun 23, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Advent k200
Probably a motherboard fault have to go to the repair shop
Jul 21, 2014 | Advent Computers & Internet
My Advent quantum q200 laptop will not alow me to go onto the recovery menu and also it will not alow me to see other ways to boot it up' what can I do to get to boot up with out using a reboot di
you can reach recovery mode by first shutting off your computer. 2 turn it back on and as soon as you press the power key start tapping f5 constantly and your screen should go into safe mode. you can the put your computer to recover or set it back to an earlier date and time. hope this helps.
Apr 29, 2012 | Computers & Internet
How to brighten my laptop screen
There are two 'Brightness signs' on two keys of your laptop keyboard.
Press 'Fn' key (on the last row of the keyboard) and press one of these keys to increase or decrease brightness.
Sep 10, 2011 | Computers & Internet
Advent 5310 saying on screen at start up operating system not found
i have acer laptop not strat no power. when i prass strat butten LED OPEN FOR FEW SECAUND
then off automatical what i do
Jan 19, 2011 | Computers & Internet
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
Only till recovery page then boom-blank
Try attaching the external monitor to VGA port to see if you get the same problem and then post back.
Mar 04, 2010 | Sharp 12.1 in. XGA TFT Active Matrix...
Power light comes on and then goes off.
power light comes on and then goes off
Dec 08, 2009 | Acer Aspire 3680 Laptop
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen goes blank after few seconds
My screen goes black after a few seconds and will not come back on unless I turn it off. When I turn it back on it does the same thing. I can not get it to come on at all.
Apr 29, 2008 | ViewSonic OptiQuest Monitor
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
