Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Paper Jam or Will Not Feed
WorkCentre XD120F.
From either tray the paper either jams or the paper will not be picked up at all.
  • asscrazy Jan 13, 2009
    It won't feed out of the tray unless I put each sheet one at a time above the 2 pinns holding the paper in place?
  • Anonymous Mar 28, 2014
    paper not feeding
    President:
  • 2,072 Answers
Sounds to me you have worn out feed tires.
Google a business called ' the parts drop. Give them a call.
They will have what you need, and at a fair price.
Posted on Jan 10, 2009
Getting a constant "Paper Jam 071-100" error when printing from Tray 1 (no jam found).
You need to replace the paper pick up, feed rollers and separation sub-assebly.
Nov 27, 2012 | Dell 3115CN
With an old and new toner cartridge, we still get J1 error
Something else is wrong. J means there is a paper jam in the paper tray
Mar 15, 2010 | Xerox WorkCentre XD120f Copier
Xerox XD120F copy machine not pulling paper through to make a copy. Might grab paper and then jamb.
If the paper is not pulling out of the tray, you should replace the feed rollers. They are easy to replace.
If it is pulling the paper about 2/3 of the way through the machine, you would most likely have a broken fuser heat roll gear, again cheap and easy to replace.
Feb 15, 2010 | Xerox WorkCentre XD120f Copier
What does code J1 mean on a xerox work center pro?
J1 mean any paper jam in paper feed area or sensor displace.lower cassate or multi pass tray.clear jam paper then solve your problem.
Dec 23, 2009 | Xerox WorkCentre M-24 Color Copier
Paper jams just as it comes out of the tray. It's
hi.have a look at your tray feed clutch.strip and cln
Nov 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Printer won't accept paper
What jam code are you getting. I suspect a registration clutch issue. But there should be a code associated with the jam.
I would like to look that up and narrow it down for you.
Mar 13, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
154 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
