Question about Amana ACS3350 Gas Kitchen Range
Amana ACS3350 Control Units shuts down when over heats up
The oven will heat up then the control unit begins to blink, then it will go blank. After about 20 minutes it will turn on by itself again. What is the problem?
    Top Expert:
  • Amana Master
  • 9,472 Answers
Sounds like a bad safety valve Test for 3.2-3.6 volts AC at the gas safety valve with the igniter turned on. If the voltage is there, you have a bad safety valve. If the voltage is low, you have a weak igniter and the igniter will need to be replaced. You can test this with a multi-meter.
Post back your results.
Posted on Nov 27, 2012
4 Suggested Answers
  • 3 Answers
SOURCE: Model ACS3350 oven stops heating up mid cycle
Does your range ever get very very hot on the exterior, mostly by the control panels?
Posted on Aug 21, 2009
SOURCE: Amana, ACS3350, gas slid - in range, the oven will not turn
I just had the same problem. I had it repaired and it was the oven ignitor. Labor and Parts $185. I now have an additional problem and I have to call the repair person back. The oven starts up and preheats to temp I set of 350 degrees. Then after awhile it will shut off and after another few minutes the clock will come back on and blink. I will repress oven bake and it will go for a short time and then shut off. I don't know what the problem is yet. I am totaly dis gusted with this stove. The stove is only 8 years old!
Posted on Jun 17, 2010
pappapumpdaf
  • 635 Answers
SOURCE: amana ARGS7650SS Gas oven takes a
This is Amana's fault and is common on several oven models and types.
Your timer and clock control board has some loose solder joints and they can be re-attached by any competent electrical repair shop with soldering skills. TV shops can often be convinced to do this for you for a nominal fee.
Posted on Nov 07, 2010
Amana RS10D Not heating up . Fuse,2 thermal cut out, door switch, all ok. board/ magnetron/ transformer dead? Pls help. Don't want to discard 5 units...all same problem...Thanks
I regularly repair Amana commercial microwave ovens.
  • What is the FCC ID number from the tag?
  • What is the Manufacturing number (like P76695, etc.)?
  • Is it making any unusual noises?
  • Is it running quieter or louder than usual?
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 11, 2017 | Amana Microwave Ovens
Why does my oven click on and off after it heats off?
Pull the temperature probe on the unit and check the Ohms on it with a multi-meter. It should read 1100 Ohms. If you get a different reading, replace the probe with this part.
Keep me posted.
Jan 20, 2013 | Amana ACS3350 Gas Kitchen Range
1.Our gaz range (with electronic range control) Amana ACS3350AS oven bake works normally at 350 F for 40 minutes, then stops. While the broil can still work at this point, it's likely the Oven - High...
Works normally for 40 minutes? Then after she cool down will work again? Let me look un momento mon ami. Aha Your temp sensor might be faulty,
Another thang it could be is a weak ignitor,
An oven limit would shut down and NEVER come back to life. It ain't gonna be no limit er fuse.
Basic American oven fault codes and more HERE
Feb 11, 2011 | Amana ACS3350 Gas Kitchen Range
Amana ARGS7650SS Gas oven takes a long time to heat up, and then, in the middle of baking, the digital control panel goes blank and the oven goes off. Eventually, the panel will begin flashing and, with...
Nov 07, 2010 | Amana ARGS7650SS Gas Kitchen Range
Jun 08, 2010 | Amana ACS3350 Gas Kitchen Range
Nov 15, 2008 | Amana ACS3350 Gas Kitchen Range
Amana ACS3350 Gas Kitchen Range Logo
97 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
