Rheem model rged 10erajs
MAKES SEVERAL ATTEMPTS TO START BEFORE IT GETS GOING
2 Suggested Answers
  • 767 Answers
SOURCE: I Replaced control board and now unit comes on and
Check to make sure the roll-out switch is not tripping., or maybe the high limit is tripping. It is most likely one or the other. The rollout is near the burners and the high limit is up higher usually square with 2 wires coming off it.
Posted on Dec 21, 2009
Power vent 2 41vrp50n
Copy following links for troubleshoot by type of gas control valve, error codes and diy resources:
2 flashes might be pressure switch failure:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pressure
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Rheem does not post service manuals, as consequence almost all water heater questions on fixya are about Rheem products. However other companies use same gas control, and have service manuals available that might assist.
Call for service technician.
Gene
h
Sep 11, 2013 | Water Heaters
I own a 99 Boxster that recently has a problem starting. Sometimes the key turns, makes no sound, not even a click, and will not start. Other times the engines turns right over. It will always eventually...
hello there
You will most likely need electrical portion of the ignition switch.It is a comon problem and not hard to replace
here is the part number for "ignition starter switch" is
A 4A0 905 849
proporsche
Sep 04, 2011 | 1997 Porsche Boxster
My electrid rheem hot water heater makes a loud pop sound after using hot water to fill bath tub . Why?
The sound is the water heating through mineral buildup in the bottom of the tank...
The water gets superheated (boiling) because the mineral traps it aroung the element for too long....then it makes the noise as it percolates there....
How to Clean Hot Water Heater
heatman101
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My powercom UPS model no. is IND601A.It shuts down on its own with beep going off.the device doesn't function at the first attempt but it takes 4-5 attempts to get started.I mean to say when press start...
Please open and check your battery. possible that it has gone weak. Put the set on and do not switch off as the batttery needs the trickle charge to keep fit.
This is do-it -yourself site and we do not recommend any company.'But check for a search for Powercom Power supplies.. Might help.
Sep 02, 2010 | Powercom Computers & Internet
Dec 21, 2009 | Heating & Cooling
Car won't start when it gets cold.
Sir,
You are suggested to check you plug wires they might be getting too much carbon on them and another thing is that you can get your car serviced and air filter clean if not done above 2 weeks.
Nov 18, 2009 | 2004 Saturn ION
Not enough hot water
Makes you feel good to save some money right? Have a great day!
Apr 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
1996 Maxima Starting Issue
My car was having the problem I had my ingnition switch change, stater and a new battery and now it's fine.
Oct 25, 2008 | 1996 Nissan Maxima
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
