Any ideas on HOW to pull off the AGITATOR on a 40-yr old MAYTAG-A606 ?
Need to tear down and replace bearings
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
On that model I believe you remove the cup on the top of the agitator and then the bolt that holds the agitator to the stem. Here is a diagram of the assembly.
Posted on Nov 27, 2012
  • 2 more comments
  • pizzaman_2fo
    pizzaman_2fo Nov 28, 2012
    Thanks Richard, but I see NO BOLT !. Is there a special "puller" device I can make for removal (similar to a battery cable puller) ?
  • Richard Roth
    Richard Roth Nov 28, 2012
    OK, I have never actually worked on that model. Take a look at this diagram I found in my database.http://cdn.appliancepartspros.com/images...
  • pizzaman_2fo
    pizzaman_2fo Nov 29, 2012
    The diagram does NOT show a bolt, but it does show a part 2-6478. What IS that ? Maybe it's a screw... or just maybe I am SCREWED !
  • Richard Roth
    Richard Roth Nov 29, 2012
    You got me! I have never work on one of those beauties.
Jimster
  • 240 Answers
SOURCE: MAYTAG PERFORMA
Hate to say this, but if its not agitating, its probably a transmission problem. The transmission will lock up in spin mode. The Maytag's are pretty bad about this problem. Sorry to say, but probably pretty costly to replace the part as well. Good Luck!!! Jim
Posted on Sep 09, 2007
docjohn174
  • 943 Answers
SOURCE: Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Posted on Sep 17, 2008
duby1990
  • 370 Answers
SOURCE: strange sound Maytag top load washer about 4 yrs old
It sounds like your bearings went bad. Using powder soap kills the bearings. THis also depends on the model of maytag. IF you lean the washer back look to see how many belts it has. if it has one it is really a maytag made by amana. Those are known for bad bearings. So good luck with your bearing problem. You will probably have to call out a technician Its a big job.
Posted on Nov 18, 2008
TheMobilian
  • 8220 Answers
SOURCE: My Maytag Washer Model A606 just quit working. No
The small fuse will prevent water from filling if it is blown. .3 amp
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 10, 2009
  • 51 Answers
SOURCE: owner's manual for Maytag M300 washing machine
go to their web site should find it there if it's not to old of a machine
My maytag front load washer 5 yr old Makes a rubbing noise on spin
It sounds like the balance is off due to the bearings being worn. It might be a better idea to look for a new machine. It is a difficult job. Parts alone will be 500-600 dollars
Mar 28, 2012 | Maytag Washing Machines
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
My 80 series kenmore washer will not agitate unless I push down on the center of the part that agitates. it pins fine. is this something I can fix myself? is it worth fixing or should I look at replacing...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
In answer to your other questions:
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Oct 24, 2009 | Kenmore Washing Machines
Owner's manual for Maytag M300 washing machine
Jun 10, 2009 | Washing Machines
Today my maytag top loader had a string get caught under the agitator. It sounded like a jack hammer nad then started smoking. I shut it off, pulled the plug, took out the contents, plugged it back in and...
the agitator is held down by pins, the pins are attached to bracket, the bracket is attached to bearings and motor. Either the motor or bearings could be shot. Also there is a belt that spins the motor. IT is very likely that the belt kept spinning while agitator was stuck and burned the belt off.
Apr 07, 2009 | Maytag Washing Machines
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
How to remove agitator
remove the agitator by grasping firmly and pulling up towards your chin, carefully!
*( many have 1/4 hex head screw on agitator, down the side near the base, older ones have a rubber ring on transmission shaft 63d52cc.jpg
Oct 29, 2007 | Maytag Atlantis MAV6000 Top Load Washer
MAYTAG PERFORMA
Sep 04, 2007 | Maytag Performa PAV2200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
