Question about Bosch Washing Machines
Bosch wvf 2000 washing machine not draining
Clothes coming out soaking After each wash I have to remove filter at base and water comes gushing out . Would appreciate your help.
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx WFL 2462 Front Load Washer
Remove plastic panel at front bottom of washer, there you will see the filter, unscrew it anti clockwise to remove and clean, replace and tighten up clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 17, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
e-Guru
  • 3917 Answers
SOURCE: I have a Bosch WVF 2401 the wash is coming out too wet
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles. It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle. It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump. It's also possible that the drain hose from the pump to the drain may be partially clogged. It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the controls mechanism which manages the the starting and run time of the pump.
Firstly, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing. It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller. If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe. It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle. If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective. A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
OR
If your clothes remain wet after your washer’s spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
Thanks for contacting fixya.com
Posted on Nov 07, 2009
Testimonial: "e-Guru came back with a fantastic series of solutions and I am most grateful."
BOSCH WFFF2000 WASHING MACHINE DOES NOT SPIN
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 24, 2011 | Bosch WBB24759GB Washing Machines
Bosch wft 2400 has stopped draining water after a cycle. What do i do
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
John C
Feb 26, 2011 | Bosch Classixx WVF 2402 Front Load...
Washing machine won't let water out
pump blocked need to unplug machine and remove back and find pump this pump will need to removed and cleaned or replaced . if you do this your self you will blank or towels on the floor because there could be lts of water . Better to phone your local engineer . cheaper than manufacture.
Feb 11, 2010 | Bosch Classixx WVF 2402 Front Load...
My Bosch WVF 2402 will not drain
Tyere should be a filter located at the bottom right front of washer, behind a drop down cover.
Unscrew anti-clockwise to remove and clean.
Dec 30, 2009 | Bosch Classixx WVF 2402 Front Load...
How do you check if the pump is blocked on a bosch classixx washing machine manual? Bottom right at the front, I guess. What do I do? How much water will come out - a towel's worth? Should I place a tray...
The pump is as you say located at the bottom front right of washer.
Remove the bottom cover if there is one, unscrew the filter handle to the left, and remove same.
There will be some water, but not a lot.If there is al ot of water in,before you remobve filter , lay the drain hose down low to syphon the water ou
It is a fairly straightforward procedure.
Please rate my solution.
Thanks.t.
Nov 24, 2009 | Bosch Classixx WVF 2402 Front Load...
I have a Bosch WVF 2401 the wash is coming out too wet the spin dryer is not extracting enough water out of the clothes - is there a filter I need to clean out?
OR
Nov 07, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Thanks.
Jan 16, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Washing Machines Logo
173 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
