Question about Dayton Water Heaters
How do you find a replacement element for a dayton water heater? My plumber said the top element is fine but the bottom one is bad and he has never seen one that is connected with 4 prongs/bolts...usually only 2...and we cant find a replacement element anywhere
  • Dayton Master
  • 5,089 Answers
1) Do google image search:
http://industrial-surplus.com/index.php?cPath=550&osCsid=66c069fdc226f10e3291a24026bf754e
2) Check local hardware store.
3) Check ebay
4) Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Nov 27, 2012
  • Mike Cowin Nov 28, 2012
    Thanks for the help! My plumber was able to locate the correct element and is installing it this morning. = happy wife!!
  • Gene Haynes Nov 28, 2012
    Congrats: My local Ace hardware carries following element:http://www.drillspot.com/products/158457...
  • 2692 Answers
SOURCE: top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Posted on Jan 24, 2009
  • 2692 Answers
SOURCE: how do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
Posted on Feb 11, 2009
  • 659 Answers
SOURCE: No hot water, Rheem Model RR612T, Electric Hot Water Heater, 60 g
If you don't have current, 0v from terminal to terminal, then you don't have voltage to the elements. Replace the thermostat but check that you have 220v to the thermostat. It is possible that your breakers to the unit are either bad or tripped.
Posted on Apr 07, 2009
  • 48 Answers
SOURCE: Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Posted on Jan 16, 2010
  • 8404 Answers
SOURCE: I have a Rheem 81v52dt 50 Gal Elec heater. I can
There should be a flip flop circuit in your heater that switches between the two heaters. I don't think they both heat at the same time. Check the rating on the indivitual heat element then compare that with the data printed on the heater RE: maximum WATT rating.
Now then, what did you miss - I'm thinking you missed the ohm reading. You measured 220 Volts but you did not check to see if the element is burned out or not. Move your meter to OHM and take a measurement with the power turned off. If the reading is "open" the element is buned out. If you get some reading beside 'open' the element is probably able to carry current.
Have you drained the sediment from your heater recently?
All the way up is a dangerous setting by the way. I suspect you know this.
Thanks for your interest in FixYa.com
Posted on Feb 19, 2010
Testimonial: "Clear, concise advice. Saved me lots of time. Problem not solved yet but I am heading in the right direction."
My fleck electric boiler has just stopped producing hot water only cold coming through taps help. Thanks in advance
there is a tube in the cold water line going into heater they rupture and then water does not go to the bottom of the tank .call a plumber and have it replaced if bad if it is not that then the elements have gone
Aug 02, 2015 | Water Water Heaters
My caravan carver heaters pressure relief vale keeps blowing any ideas please
Not familiar with that exact heater but if it is an electric heater with a top and bottom element this may be the problem. Electric water heaters usually heat water off the bottom element. If a lot of hot water is used then the top one kicks in through the temperature controls. In some cases if the bottom element burns out, it will try to heat everything with the top element. This sometimes causes the water in the top of the tank to actually get too hot and it opens the relief valve. So you may have a bottom element bad. Otherwise your relief vale may need replaced or you have a sticking temp control making it get too hot.
Apr 11, 2015 | Water Heaters
Premier Plus Model#MHE62-30H-045DV Ser#45T421608 I just purchased this hot water heater.I had it professionally installed by a plumber.We had hot water before I went to bed but when I woke in the morning...
sounds like you have a power problem. or worst than that a leak . So lets look at the leak first. Turn off the water supply at the water heater on top. This valve should be on the cold side of the heater on top.
Turn it off, check and see if you have pressure in the house by turning on a faucet. It should run for a second then stop. That is good if it does. Leave the valve off on the heater and check that your breaker is on. Reset the breaker by turning it on and off.
Wait about 2 hours turn the heater back on and check to see how hot the water is hot then you might have a leak in the building. If there is not or little hot water. Check the wires where it connects to the water heater. You might only have one wire that is connected right.
The best thing to do is to get a amo meter and check to see if you have 220 if you dont have 220 you will not warm up the water the way it should.
Thanks Richard
Sep 07, 2011 | Premier Water Heaters
Have a new electric tank,top element wont come on,replaced thermostat 3 times top element comes on once but next morning not enough hot water&top element wont come on,can someone help? thanks
The top element only comes on when the heater is about out of water. The water is directed to the bottom of the tank. Cold water stays on bottom, Bottom heater element heats water. If you use all that water then the top of the tank gets cold and the top element comes. When the top of the tank is warm, then the bottom element comes on. I would susupect the bottom element as it does most of the work. If you have an ohm meter, turn off electric, and remove wires from element. Check element for continuity. If you don't get reading, then that element is bad.
Oct 04, 2010 | General Electric Water Heaters
We had no hot water so we check the elements with a voltage meter and found the bottom element to be bad. We replaced it. Now there is still no hot water. When we test the voltage again there is continuity...
The elements never run at the same time, it would take to much energy for a standard residential heater. Instead, they rotate powering up back and forth depending on the hot water demand. If you getting 208 to 240 volts on the top element and nothing is happening, the top element is bad and needs to be replaced. If you can swing 30 bucks, replace both elements and both thermostats at the same time. This way you know that everything is new. Check out this generic water-heater wiring schematic.
Sep 06, 2010 | Reliance & 50gal Electric Water Heater
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Water is no longer hot
A heating element is either good or bad and no inbetween. If your unit has two elements, then one of the elements is bad. If it is a single element unit then the thermostat has gone bad. Do a voltage check to see if you have power going to both elements and if you do then do a ohms test on the elements. They shoudl read 5 to 10 ohms. If one of them doens't, then you know it is bad. If by chance check the elements and everything is working, the only thing that can be left is that the dip tub has ruptured somewhere close to the top of the outlet. But I would put my money on a bad element.
Apr 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I REPLACED THE HEATING ELEMENT IN THE TOP OF THE WATER HEATER AND IT DOES NOT STAY HOT FOR VERY LONG IS THERE SOMETHING ELSE TO REPLACE
Well by replace the top element is proable not the problem.You see the top element heats the water at the top first and then the bottom take over.So, my guess is the bottom element is bad.Replace it and I think your troubles will over.
Mar 15, 2009 | Water Heaters
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
62 people viewed this question
Top Dayton Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Dayton Water Heater Expert? Answer questions, earn points and help others
