Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Defrosting candy freezer cv12/9
This freezer came with the house, no instruction manual. do we just turn it off & wait for it to defrost or is there a quicker way to do it? what is the slide for in the bottom?
    President:
  • 1,214 Answers
Manual defrost usually takes about 2-3 hours, depending on how much is built up. You can speed things up by using a hair dryer (just be careful not to allow water to splash inside of the dryer.).
As for the slide at the bottom, I could not tell you without seeing the unit, manual, or sales brochure.
Posted on Jan 15, 2009
Defrost instructions
Manual Defrost model freezers must be defrosted manually. For best operation the freezer should be defrosted when the frost accumulation becomes 1/4 to 1/2 inch thick.Defrosting Instructions for Upright Freezers: Turn temperature control to OFF and unplug freezer.
Manual Defrosting Instructions for Upright Freezers
products.geappliances.com/appliance/gea-support-search-content?contentId=19298..you can also go to this link that should help you out... Defrost instructions Google Search
Oct 23, 2017 | Refrigerators
Why is my fridge freezing up in my candy fridge freezer
Hello there,
The reason your fridge is freezing up is simply because there is a problem with the defrost unit of the refrigerator. The defrost thermostat simply could have gone bad and therefore is not getting the defrost heater to start work.
Have the defrost thermostat tested and replaced once found faulty.
Hope this was of help to you. All the best Elect_Comp
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
I have a candy fridge freezer - the freezer is fine. When the fridge to turned up to max - the food in it is not cold. How can I resolve this? If I defrost the fridge - could this help? Thks
Defrosting the freezer will temporally solve the problem. There could be a problem with the defrost cycle or the evaporator fan. a technician can help you there
Apr 01, 2011 | Refrigerators
New pcb not turning compressor , but the old one does when pluged in
Does your New PCB have a defrost timer attached? If it does, you will need to wait for the defrost cycle to complete before the compressor will start.
Mar 09, 2010 | Candy CPCA240FFK Bottom Freezer...
I have a candy frostfree fridge freezer GL90AA; it never switches off,i.e. I can hear it run all the time.
If it is not reaching the cut off temp because
the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everythinghttp://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 08, 2009 | Candy CPCA240FFK Bottom Freezer...
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually...
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Jun 18, 2009 | Magic Chef Refrigerators
- fridge not working following defrost
There must be a model number on the unit somewhere. Look on the door jambs on the cabinet (not door) side of the open doors.
Most modern day freezers have automatic defrost systems built in. If your does not defrost, then we need to troubleshoot why.
Post your model number, and we can proceed, assuming you or someone you know, knows how to use a multimeter and read a schematic/wiring diagram, with my help.
Jan 15, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge freezer
Defrost timers usually cause this type of frost build up. However it can also be caused by the defrost heater and/or heater thermostat, and these items are behind the panels therefore not easy to get to. Also before you attempt to take the panels apart make sure the refrigerator is unplugged.
Aug 04, 2008 | Candy Freezers
Fridge freezer icing up
YOUR DEFROST TIMER COULD BE STUCK,FIND IT ON BACK OR FRONT OR INSIDE TURN SLOW CLOCKWISE TILL CLICK,IF FRIG. IS RUNNING IT SHOULD TURN OFF AND GO TO DEFROST,ALSO THE DEFROST HEATER IN FREEZER COULD BE BAD,OR THE TERMINATOR IN FREEZER COULD BE BAD OR THE FREEZER FAN MIGHT HAVE STOPPED,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
May 29, 2008 | Candy CPCA240FFK Bottom Freezer...
Orange flashing "Super" light
FORGET THE LIGHT FOR NOW,REMOVE FREEZER BACK PANEL,MAKE SURE FAN IS WORKING,FIND THE DEFROST TIMER BOTTOM FRONT,OR ON BACK,OR INSIDE FRIG.TURN CLOCKWISE SLOWLY TILL YOU HEAR CLICK,THEM GO BACK TO FREEZER SEE IF THE DEFROST HEATER KICK ON YOU SHOULD SEE THE ICE MELTING OFF,IF NOT YOU HAVE A BAD HEATER,YOU SHOULD REPLACE TERMANATOR TO ITS A LITTLE ROUND CLIPON ON OFF SWITCH FOR HEATER,NOW WAIT ABOUT 20-30 MINUTES TO SEE IF FRIG. COME OUT OF DEFROST IF IT DOES YOUR DEFROST TIMER IS GOOD,YOU CAN ALSO CHECK HEAT WITH OMES METER IF YOU KNOW HOW,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
Feb 08, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
222 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
