Try this,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
SOURCE: I have the same problem as djeff757 post on Kitchenaid KDRP467
I don't recall a control panel fuse for this model, there is, however, a thermal cut-off on the rear of the unit. The part number is 8300802 and you simply have to remove the rear panel to access it.
SOURCE: Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
The problem is: the temp seems to be 'stuck' at 260 and will not allow any higher settings.
Calling KitchenAid proved to be unuseful. The manual did not have this item in the troubleshooting pages. Resetting the power does not help.
The SOLUTION:
There is really no problem besides that the temp display setting has been somehow set to be celsius (metric system) rather than farhenheit (english system). Changing this setting somehow can be easily touched off without knowing, thus the "I didn't do anything and yesterday it was working fine..." comment from family members.
The FIX:
Reset the temp display back to farhenheit (F). This is done by opening the oven door, then hold down the 'Broil' button until you hear a beep from the control panel. The same method may be used to change from Farhenheit back to Celsius.
Prevention:
I speculate the inavertent change of the temp setting is done while cleaning the flat control panel. So the best thing to do is to always 'LOCK' the control panel when cleaning the controls. This is done by holding down the keypad "3/lock" for a few seconds until the display shows LOCK.
(The solution was already posted when I arrived at this page. I just organized it a bit by adding some details and a preventative comment. Many thanks to those who posted earlier, solving my issue as well. I hope my writing presents a clearer and quicker read to the next person)
SOURCE: Kitchenaid KGSA906PSS00
I recently encountered this issue after trying "self clean" on my
KitchenAid oven for the first time. I wish I had read these forums and
simply avoided the feature. KitchenAid was, of course, completely unhelpful since my warranty was expired. This is the first they've heard of the problem; perhaps search engines are prohibited within the KitchenAid community and they are unable to view the complaints of thousands of other customers as I have... but I digress.
The solution was straight forward: Don't worry about the locked door for now and pull the oven away from the wall. Safety first: unplug your oven and turn off your gas valve. Now remove the back panel. There is a sheet metal strip near the top of the oven that must be removed before the back panel comes loose. With the back panel removed, look for a circular device with a blue and white sticker on it and the part number: 8300802. This is a thermal fuse that blows when the oven gets too hot (apparently "too hot" is a subjective measure as normal operation during self clean will cause this issue). You can check it with a multimeter if you have one... a failed fuse will have a high resistance. To ensure this is your only issue and to immediately unlock your door, adventurous types can bypass the fuse by connecting the two wires that connect to the fuse and hold them together with some electrical tape. WARNING: never operate your oven in this manner. This is a quick test to verify resolution of the issue; not a permanent fix. Apply power to your oven and presto, your door will unlock and your front panel will illuminate.
Now, use the aforementioned search engine KitchenAid has never heard of and search for your new fuse: 8300802. I got mine for $34... you can probably find it for cheaper but my patience was wearing thin by the time I got to ordering a replacement part.
Oh, and one last step: never ever under any circumstances use the self clean feature. Do not take the easy route like I did: get your Brillo Pad and your Easy-Off and get dirty, you lazy bum.
SOURCE: Kitchenaid Oven won't work E0 F2 on the control pad
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
