Question about Canon PIXMA iP1800 InkJet Photo Printer
How do I reset my canon ip1900
My printer is flashin the yellow light 5 times then the green once alternately and it will not print. What should I do please?
efs_perpends
  • 1996 Answers
SOURCE: flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 24, 2009
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
SOURCE: CANON IP 1880
i need install canon ip1880.. how?
Posted on Oct 05, 2008
manuel-d
  • 5 Answers
SOURCE: Canon Pixma ip1900 Printer wont print
i think you need a canon resetter just download it and it will fix your problem. gud luck ellyhill
Posted on Nov 16, 2009
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Resetter of canon iP1900
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1900, iP1300 Printers
  7. Press the Power button and the Canon Pixma iP1900, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1900, iP1300 Printers should respond as normal
Jul 06, 2011 | Canon Office Equipment & Supplies
Hi, The orange light in my canon ip1600 printer is blinking 5 times and green light once alternatively. Please give me a solution to fix it. What is the reason behind this problem? Thanks.
3. Release RESUME
Jun 25, 2011 | Office Equipment & Supplies
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
5 yellow blinlking lights. Power on/off doesn't clear the lights. Won't print. TIA...
Canon IP3000 INK counter reset
1. Turn off printer
8. Your printer should respond as normal..
Can try it may work all the best of luck
Feb 15, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Feb 12, 2010 | Canon I960 InkJet Photo Printer
3. Release RESUME
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
1. Switch off the printer the button Power
2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
3. Holding button Power , release the button Resume
4. Not releasing button Power , two times press the button Resume and release both button.
5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
Jul 09, 2009 | Canon Office Equipment & Supplies
Canon S400 lite binks 6 times won't print.
1. Turn off printer
Dec 27, 2008 | Canon S400 InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
686 people viewed this question
old marine
old marine
