Question about ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard
When ever I start my computer it directly goes to bios settings and it says *********** board frequency not set properly. I tried with every kind of frequency but it did not work out and also it takes long time to get start. Mother Board - ASUS P4BGL-MX , I bought this 2004. Please give me the solution.
  • 124 Answers
You should check the BUS frequency as well, for the RAM. If the ram and mobo frequencies aren't set in a pair, but board won't work properly. Is there an option to set to factory defaults? I'd use that.
Posted on Jan 10, 2009
Only reading half of expected value of memory installed. Have 2 512mb installed but the Bios indicates that they are each 256mb. Computer is set up for dual mode with 2 slots. I am using Windows XP PR
Most motherboards need to be told they have updated memory installed. This is either done by Contacting the motherboards manufacturer for upgraded bios that will be needed for the motherboard to receive higher RAM cards. These should be available through the "support" section of their website. If you own a Dell or HP, their bios are usually locked and must be updated this way. If your bios are "cleared" you will have full access the change the RAM MHz and RAM value settings for the board to match your new RAM cards manually. Open the PC's BIOS and search for a RAM frequency and value settings. The precise location varies depending on your system, but it's often in an "Advanced Chipset" section, on a page that mentions RAM or DRAM configuration. Modify the RAM frequency and value to match your new cards. Your new cards will have their MHz rating and size either on the box, the included paper work, or on a sticker or indicator stamp on the RAM card itself.
Exit the BIOS with the "Save Settings and Exit" option and let your computer restart.
If bios are compatible or updated and still not booting. Try installing only 1 new card into slot two at a time, leaving 1 of the original cards in slot one. Turn on the machine and go to your bios and change the values only for card 2, save and reboot the machine into bios once again. Then change the value for slot one to match, save and shut down and install the other new card into slot one.
Nov 22, 2017 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Vostro 200 beeping when i start it up
Usually the beeping at start ..and the result being non boot..is related with the ram memory ..The thing to do is to open it up ...remove the power cord...remove the ram memory ..(do not touch directly ...handle them from the ends..) After that place them back firmly ...be sure the safeties from the ends are closed proper..and ...before restarting ..remove the bios battery for 30 seconds..to reset the bios settings to teh factory values..
restart it ..and if it works..it may ask you to press F1 to go to bios settings and in there you will have to set the time and date ...If you seam not to manage to do it .....just press F10 when you are in BIOS ..and this will save the setting and restart ..after that you will set the time and date from windows directly ..
If it still not starting ..and the beep goes on ...it means the ram memory is corrupted...or ..if you have more than one module ...one of them is ...and in this case you have to remove them all ..and try them one by one ...
basically ..remove all ram ...and start by inserting just one ..and boot up ...if it works ..the module is functional ..and you keep it in place ..and insert another..In the moment the ram memory is not read..the value on start will not be modified..or the computer will not boot up ..
If you only have one module ...and it seams to be defective ... you will have to buy a new replacement ...and in this case you have to be sure you buy a compatible one ...be sure the frequency is the recommended one ..and the size in Mb is not exceeding the maximum supported by the slot..
For example ..there are ddr1 ...ddr2 and ddr3 slot model ...and for each module you will have on it the value on Mb ..for example 512Mb or 1G ..and also ...a frequency in Hz ...for ddr1 you can use any one you find cause the fq is only until 400Mhz and will work with inferior values...but for ddr2 and 3 you do not have to exceed the maximum or the value recommended ..for example ..if you have a ddr2 on 667 Mhz ..you will not be able to use with success a 800Mhz one ...it may work ..but will make issues on boot ..and will usually read half of the value ...(512M instead of ! G ..and so on ..)
Another issue ..may be the ussage of a larger value one and the computer not being able to read it ...so ...read in teh tech manual first under the ram memory ..what exactly are the recommanded ones..and buy them according with that ..
Good luck .
By the way ..it is a good idea to reinstall the operation system after installing new Ram memory ...expecially if you change the manufacturer and the values..(upgrading )..
Nov 01, 2011 | Dell Vostro 200 PC Desktop
After BIOS upgrade from fdd motherboard C2SBX Supermicro does not starting. Coolers are starting, but not video and not starting BIOS.
Reset the bios (use the proper jumper or rmove the cmos battery for some minutes) and start the pc. Enter the bios settings and locate and load "setup defaults". Save and reboot. If everything works fine make any changes you need at bios settings. I assume that the bios update procedure finished normally, without crash or power failures.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 10, 2010 | SuperMicro C2SBX Motherboard
CPU frequency nc6320 change when ac power in
Try to rebbot the computer then before entering winwdows, if you are using windows click F2 or F11 on some PCs to enter the BIOS Settings. On the BIOS SETTING you can see options. Click on the Set Bios Defaults then press YES then Escape.
Feb 02, 2010 | HP Compaq nc6320 Notebook
GIGABYTE-M720-US3 wont run post when turned on
If the MB is new, try swapping power supplies, RAM, processor. MBs usually can't post without these 3 items all functioning properly. Start with the cheapest first.
Aug 27, 2009 | Intel Motherboard
Problem with motherboard
Aug 30, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
CMOS checksum bad 0085
the problem might lie in the fact that the mother board and cpu cannot be handled at the speed
or it requires the jumpers to be set by so that the cpu can be clocked properly if you got a mother board spec guide follow the guide for *********** board to set up 3.2
you might also have to set the bios to the cpu speed cause if mother board doesnt do jumpers no more the setting would be in bios
hit the delete key direct are power up this will take you to bios
its not the battery
Jun 05, 2008 | Intel Motherboard
Motherboard Jetway V880DAS, PCU Athlon xp 2800, Memory PC 3200 2Gb. Bios Update 880DASA7.BIN .Operating system Windows XP Pro with Service Pack 2 I Set the CPU FSB Jumper to 166 Mhz.The computer keep...
is this the first time you encounter this problem with the athlon Xp? i have encounter this already with my PC. you should update again the bios of your computer, and load the setting of your bios to the default settings.. try to restart your computer.. and try to contact me as soon if this works for you. thanks!
Apr 15, 2008 | Computers & Internet
CPU model not recognized correctly
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Feb 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
No power to monitor
Is the Bios rom set to the on board settings for the video driver?? Did you allocate enough ram for your video driver in the Bios rom?? If all thats ok then the on board video driver is bad or not configured properly. Try disableling the On board video driver and stick a video driver card in and try and see if the monitors working correctly. Good Luck
Jun 13, 2006 | Samtron 76df 17" CRT Monitor
ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
