Question about CDA CI592 Front Load All-in-One Washer / Dryer
Washing machine will not switch on
I've just used my washing machine, however, half way through the cycle I heard a bit of a noise coming from it so I went to check and it had finished. There was lots of water left so the cycle clearly hadnt finished. I've tried repeatedly to restart the machine but the red light doesn't even come on to show that the machine is active. I could smell something as if the electrics had been overworked.
    Top Expert:
  • CDA Master
  • 78,267 Answers
I think you washers control board has go south, caput etc.
Posted on Jul 15, 2017
3 Suggested Answers
  • 130 Answers
SOURCE: the rubber round my washing machine door is black and smells
common problem with that style machine. Try running a cup of vinegar thru te wash cycle. The acid from the vinegar will break it down. It may take more than one cycle if its really bad. Once the smell is gone leave the door slightly ajar to prevent it from happenig again.
Posted on Feb 28, 2009
iwillfixforu
  • 619 Answers
SOURCE: Washing machine would not spin the clothes propely
Some dbris is in the punp which will hinder the pump out. Clean out the pump and you will be fine. Good luck and this is not a hard job at all to do.
Posted on Jan 31, 2010
Bosche axxis washer spin cycle ticking noise
Assuming everything else is working normally, I would still suspect there is an object that is getting stuck between the rotating drum and the outer housing. Maybe not coins, but something longer, like a pocket comb or the wire inserts used in some garments. It is easy to take the top off of the unit, and this might help to isolate the noise better. Early spin is usually a bit unbalanced, so it is possible it could also be something really simple like a hose clamp that has sagged enough to be contacting something else, and it only shows up when the machine is bouncing a bit.
Mar 16, 2013 | Bosch Washing Machines
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
I have an F&P MW612 washing machine that stops at the start of the spin cycle leaving water in the machine. After pushing the pause button, looking inside, closing the lid and restarting I've heard...
Something may have been stuck in the drain pump impeller creating the clanking noise. This is a serious problem that can lead to the burning out of the motor controller module, the machine's "brain". It has been found that a short circuit is imminent on a leaky drain pump which can eventually burn out the motor controller module.
Empty the machine then lay it's front on a padded floor/surface and check the drain pump including the diverter valve where both the drain pump and the recirculation pump connect from. Replace the drain pump if damaged or leaking to avoid further damage to the motor controller module.
Fault Code Reading on Fisher and Paykel Top Load Washing Machines
Aug 23, 2011 | Washing Machines
We've been given a spare Bosch Maxx 900 washing machine by friends which hasn't been used for a few years. Have plugged it in, connected the hoses, and switched it on for a standard cycle 40...
Hello is this a front loader machine and if so in the back of the machine there are 4 bolts that go thru a 3' piece of plastic. they should be around the drum area they use these to keep drum stable while being transported so look for them. Hope this helps you out
Jul 21, 2011 | Bosch Washing Machines
Hi, We have just moved and relocated our washing machine. The problem is that the wash and rinse cycles for all types of cycles is coming into the machine hot, extremely hot. What did we hook up wrong?
It's hard to say without more details, but normally, these machines have two hoses, each connecting to a seperate water spigot, one for hot, one for cold. You don't say how you hooked these hoses up, but it's possible you've crossed the hoses. It's also possible you've hooked up to a faucet that has only ONE spigot, using a "Y" connector. Take a look: You must have two spigots, and each must have a hose going to the appropriate water intake on the back of the machine. They should be marked "HOT"/"COLD" (or, possibly red for hot & blue for cold). If this is not the problem, then you have a much trickier problem that will involve bringing in a trained professional. Good luck.
Apr 20, 2011 | GE WCVH6260FWW
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
CDA CI592 Front Load All-in-One Washer / Dryer Logo
74 people viewed this question
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
