Question about RCA R52WM24 52" HDTV Projection Television
Can't access to adjust convergence on my rca R52WM24 tv.
The manual has it listed in the set up menu but it isn't ther in mine. is there another way to access it
  • 1 more comment
  • carolkush Jan 10, 2009
    didn't help.. i got into the service menu but don't see the word convergence anywhere.. help
    if it is the fl231 fuse is it easily replaced. will this allow me to adjust the convergence thru the menu
  • carolkush Jan 17, 2009
    so i contacted rca no help they say to unplug and it will reset NOT. then they say it isn't common and to call a service guy. Called the name they gave us not much help and needs me to bring tv to him approx 400 bucks to fix. i need some clarification about the fuse fl231 that people have mentioned. does that fuse control the convergance or the menu
  • RCA Master
  • 1,527 Answers
Not sure if this will work press mute 183 on remote control
Posted on Jan 10, 2009
  • shaun taylor Jan 10, 2009
    sorry that didn't work . i think the convergance chips will need to be replaced and resistors and capacitors
    shaun
  • shaun taylor Jan 18, 2009
    i don't think it does the convergance chips control the convergance it sounds like these are the problem
    shaun
I don't have my original remote for my rca rear projection tv can i still adjust my convergence
mine is in the set-up menu accessed from the buttons on the front of the tv
Jan 19, 2013 | RCA Televison & Video
RCA r52wm24 projection hdtv. Colors of tv not aligning images look like they are in 3d without glasses.
this is called convergence.the first step in diagnoseing this set is to go into customer menu under the setup option. DO you have the donvergence listed in this menu. if you dont read this http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in. if you do then try using autoconvergence and manual options in this menu. if it doesnt work then more than likely you will have some faulty components in the convergence cuircit. let me know and ill seel if i can help more
Oct 30, 2010 | RCA R52WM24 52" HDTV Projection Television
Have a 56" RCA that i had the user manual for and lost it. i used to do the manual and auto converge. its been so long i forgot how to access it. help?
press menu then scroll to setup the auto convergence features are listed there. If they have disappeared you will need the ITC222A convergence option missing repair kit available from www.tvrepairworld.com
Mar 17, 2010 | RCA R52WM24 52" HDTV Projection Television
I cannot convergence my tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2009 | RCA R52WM24 52" HDTV Projection Television
My rca r52wm24 HD/TV monitior,is having ploblems with the picture, last night all of the suden the picture looks like a 3d movie with out the glasse, what is the problem
the problem is called convergence.this model was made with 2 options for convergence.first go into menu of tv,find convergence.if it has auto convergence activate it,IMPORTANT dont do any thing until its done(it will reach 100%,you can see it on the screen.the 2nd option is manual convergence,in that case you have to adjust the red onto the green then blue onto the green,DO NOT MOVE THE GREEN.both red/blue will move up and down,left and right.
Sep 24, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA HDTV
go into the menu
looking for set up tab
looking for convergence tab
looking for automatic convergence. apply.
Fixed. NO? tv has a problem in the convergence area. Technican Job
Apr 08, 2009 | RCA R52WM24 52" HDTV Projection Television
I have a rca r52wm24 hd monitor the color is bad theres 4 of everything cannot access the convergance on menu ,watched tv repair person one time and he pressed some buttons together to get into a grid and...
Shut off tv, wait 30 seconds, then at the same time press the channel down and the volume down buttons and wait for power light to come on and then release.
Sep 10, 2008 | Televison & Video
RCA Model Number R52WM24
Is this a projection set? If so you simply need to set the convergence. Otherwise I would try to return it to the retailer and exchange for different manufacturer.
Apr 22, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
208 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
