Question about Samsung HL-S5087W DLP TV
Dlp lamp light blinks but tv will not come on
Bulb lights but no picture comes on
  • erikdenholm
    erikdenholm Nov 27, 2012
    Daughter witnessed the death of my Samsung HLS5087w. Reported a loud noise (like the severe weather alert sounds) then screen went pink then died. Now when i power up the set it initializes normally, sounds normal, the bulb comes on but the screen remains grey and doesnt respond to remote control inputs. The lamp indicator just blinks for about a minute and a hlaf then it shuts down. When it shuts down no indicators are lit and there is a slight scraping noise coming from the inside of the set either from the color wheel or a fan (this is a new noise).
    Top Expert:
  • Samsung Master
  • 14,553 Answers
If the wheel is broken or missing pieces you get a grinding sound, and set will shut down as set sees it is not moving at correct speed.
with lamp removed look at the wheel.
Posted on Dec 22, 2012
3 Suggested Answers
Easyworks
  • 62 Answers
SOURCE: My samsung HLP5067 DLP powers up, but no picture
Check your TV Lamp. Most likely its gone bad. Its easy to change and readily available on the net. I cover for such problems in Sacramento area with cheapest rates. checkout for more answers at www.fixurtvs.com. The only tools you need are a screw driver and a plier. If lamp is okay,' check the fans next to it. Also buy an air duster can from walmart for about $ 4 and blow clean the lamp area before you intall a new one. It will ensure long life of your new lamp.
Posted on Feb 21, 2010
Testimonial: "Worked perfectly. Thank you!"
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My Samsung 5676 DLP was blinking all three lights, I put a new bulb. Now it blinks the outer two lights. i still have no picture and the bulb dosent come on
This could be the other is you tv has 2 lamps out either maybe your board is bad i recommend a technician to check you tv
Dec 13, 2009 | Samsung Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
I need to change the bulb in my WD65731 dlp tv. I have taken the cartridge out. How do I get to the bulb. I repleced my lamp and still have no picture. Am still getting a "blinking" lamp light on front...
The blinking lamp light refers to the lamp door not being closed. There is a little lever behind the main panel and if that's not shut, the lever won't be pressed in and therefore the light blinks. If it's a failed lamp, the lamp indicator light will be a solid, not blinking.
May 31, 2009 | Mitsubishi WD-65731 65" HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-S5087W DLP TV Logo
73 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
