Question about Dryers
Urns on but will not run, check the belt...it's good and the dryer is giving me a code F 02 can you help me with this matter. ty diego
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 27, 2012
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: Ge profile dryer runs but no heat, have 220 at outlet and all switches are good. How can I check the motor switch?
It's either the fuse, heating element, thermal cut-off or thermostat
Posted on May 18, 2012
KENMORE ELITE ELECTRIC DRYER HE5 Model 11087087601
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 27, 2012 | Kenmore Dryers
My admiral dryer model AED4475TQ belt came off and the pulley is laying lose I need a diagram to fix it please help
Hopefully this helps! My drawing isn't great or good for that matter. The washer has a place to insert the pulley in front of the motor. Put the belt around the drum. Then push the pulley back away from the drum and insert the belt in between the forks and then wrap it around the pulley of the motor. I really hope this helps.
Oct 27, 2012 | Admiral AED4475TQ
Kenmore 63912 will not start.
The dryer has a safety switch for the belt. I f the belt is broke, replace it and all will be good.
Mar 11, 2012 | Kenmore 62802 Electric Dryer
Upside down letter F and #5
does it look like this? t5 or ts could be a thermistor code.if you changed out the thermistor you most likely have a bad computer board.there should be a tech sheet in the machine usually in the top console. here's something that might help http://mikemerrittmotors.yuku.com/topic/2255 the machine doesn't run is that correct?i would check the obvious things,open the door and push in on the door switch and make sure that's working correctly,it should click when you push it in,there's a switch on the belt pulley,if the belt broke the dryer won't start,then check the thermal fuse,the thermistor and if they all check good then you have a bad computer board.just have to get in there with a meter and start reading out parts,also make sure you have 240 volts coming to the dryer,you can check it at the block where the cord connects to the dryer,after that unplug it and check all the other parts for continuity and you have to remove at least one wire off of the part you're checking.also here's the sears site so you can look up your parts if you don't have this site already. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE9700AYW/3048/0151200?pathTaken=&prst=0&shdMod=MDE9700AYW good luck and wish i could help you out more
Dec 20, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer heats, but won't tumble. Suggestions?
Either there is no tension on the belt or the motor is not running. If you don't hear the motor, the first thing to check is whether any air blows out the vent. If you have air moving, the motor is OK and you can check for a broken belt or a problem with the tensioner pulley mounted on the motor bracket. First, reach inside the dryer and try to turn the drum by hand. If it turns very easily, belt tension is definitely the problem. If you can't turn it at all and the dryer was previously making a lot of noise, the drum has crashed due to a bad bearing or bushing pad. A stuck drum can also ruin a belt.
On most dryers, you can remove the panel under the door to look at the motor and belt tensioner. Usually you have to take off the floor trim piece way down at the bottom, then remove the screws holding the panel. The top of the panel is commonly held in place with spring clips.
On some models you have to undo screws at the back near the top, then tilt the top up like the hood on a car (there are spring clips holding the front of the top; you may need to pry with a thin piece of hardwood or a screwdriver with tape wrapped around the shaft to protect the paint on the dryer). This gives you access to clips and screws holding the front onto the dryer. If you have a broken belt, you'll need to remove the front (door assembly) anyway to replace the belt or drum bearing. (Some models have a drum bushing on a center pin in the back of the dryer; you can get at these by removing a plate on the back).
If the tensioner pulley has a lot of slop in the bearing, fix this; otherwise the belt may wobble off it again. You'll be surprised by how much quieter the dryer gets.
If the motor is not running, check for a failed starter capacitor (located inside the control panel), a bad centrifugal switch (inside the motor), bad contacts in the timer (control panel), or an open thermal fuse in the motor.
CAUTION: unplug the dryer before doing any work inside.
Jun 06, 2011 | Dryers
Dryer gives heat but don't run you don't hear the motor running
heatman101
May 23, 2011 | Dryers
I have a Elite Smartdryer HE3 dryer. Went I am about to press start it make a beep sound, but it doesn't start and give a F70 code.
heatman101
May 05, 2011 | Kenmore Elite HE4 Electric Dryer
Good morning I have a Elite Smartdryer Model HE3, went I take the option start it makes a beep sound and the give me a F70 code. My dryer was working properly I don't know what think may have been...
heatman101
Dryer won't start, i have unplugged and when i turn on it shows 18 min. and won't start no matter what buttons i push. i con't trying to get it started and now it does go on and i can use but i don't know...
heatman101
Apr 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The Dryer was running good rthe other day and now notta. I push the button in and all I get or hear is a Humming noise. No circuit breaker was thrown Etc. Any Ideas what u might think the Problem May Be....
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 18, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
