Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai 1004F Heating the Outdoors!
I have a propane-fueled Rinnai 1004F used to heat the upper floor of my house. I have used the Rinnai for 3 years now with no problems.
Since turning the unit on this winter, we have been going through much more propane than normal. The Rinnai has been running for long periods of time, seemingly being on more than it's off.
This morning, I checked around the outside vent to make sure a good seal exists, and that cold air was not infiltrating the house. What I found was warm air coming directly out of the vent.
Granted, it's about 5 degrees out, so the air being exhausted wouldn't take much to feel warm. But this was warm air, not 50 degree air.
I thought Rinnai used outside air to pull the exhaust out, which should make the vented air relatively close to outside temperature? It just seems that the air coming out is much too warm, and could explain why the Rinnai is running so long, so often, as compared to past years.
Anybody know? Oh yeah, I recently removed the front cover and top panel and got any dust out of the unit. So dirty filters or fans is not the problem here.
Thanks for any help/insight!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Do you have the Economy button on? If so, and you have a large space to heat or the outside temp is very cold the unit may not be able to keep up. If this is the case the stove runs forever, trying to reduce the temp by 2 degrees every 30 minutes. This may not work for your space and outside temp.
Your ideas about the intake and exhaust are not quit right. There is a fan that pulls air from outside over the outside of the exhaust pipe (to preheat it). This fan actually pushed the combustion gasses all the way out the exhaust. The exhaust exiting should be a little hot. In very cold temps, frost can build up around the air intake, which is right around the exhaust pipe. If you see this you will need to keep it clean. It is a good idea to look at the exhaust everyday when it really cold.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Posted on Jan 10, 2009
What is the average expected lifespan of the Rinnai Energysaver 1004F
http://www.rinnai.com.au/media/4357111/05604_Rinnai_Energysaver_Brochure_WEB.pdf
At the end of the document, notice there is a 10 pro rata warranty on the heat exchanger. The fact that they would offer you any money at all on a failure nine years into domestic use suggests they consider that part rather dependable. I have no access to Mean Times Between Failures on equipment. Such documents vary in calculations as what is considered a critical failure must be defined.
May 31, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a rinnai heater 1004F. Since I began using it last month my electric usage is up llKWH per day. I have it set for 60 degrees as I'm using it to take some of the load off my infloor heating system....
The question is, what was you Kw usage same time last year and is the weather warmer or colder than last year? Put an Amp meter on the black wire going to the control board and start the heater. Then check the rating plate on the side of the unit to see if it is within rating.
Mar 08, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
What part do i change when convertin a ranni propane gas to natural gas
I think the part numbers listed in the solution are LPG injectors.The orifices (injectors) needed to change over from Propane (LPG) to Gas (NAT.) would be 2 High Injectors 100F-2031-B-1.80 and one Low Injector 1004F-2036-B-1.95.
Feb 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I just bought a used Rinnai 1004f propane monitor and it came without the vent to outside. How can I get a vent? (Maybe kit) The wall is 16 inches thick. Jim Marstaller Naples, Maine
is this a vented or non vented unit? have you checked the rinnai distributorship? call Adirondack Hardware in Keeseville NY. They have parts for Toyostove, Monitors and Rinnai heaters. Their staff are very well versed in all kero and propane heaters.
Oct 20, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Blinking 12 and I have no manual to indicate what that means.
A 12 code indicates a "Flame Failure" check that the gas valve on the right side of the unit is turned on. If you are using propane have you confirmed that the tank has fuel? You may be able to download the owners manual from the Rinnai website.If not you can contact themat 1-800 621-9419.
This is a great heater and the Rinnai people will be helpful. good luck!
Oct 12, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai monitor heater 1004F
http://www.rinnai.us/Rinnai.aspx/FileLib
hope this helps
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
286 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
